70 won't turn off engine now.
Old Jul 28, 2008 | 06:34 PM
sng302's Avatar
sng302
Default 70 won't turn off engine now.
Yo , I put a new solenoid in today. After I was done the car starts fine but won't turn off with the ignition. I have to pull the black lead on the left ( I ) to get it to stop. I'm pretty sure I put every thing back right. Red lead to S , Black to I. What did I do wrong? thanks , scottg 1970 302-2v
Old Jul 28, 2008 | 09:04 PM
flickjo68's Avatar
flickjo68
Default RE: 70 won't turn off engine now.
Mine did the same thing until it eventually melted the coil feed wire and i noticed the coil was bad. I replaced it and it has been good so far. Not sure if it's the same problem, but may be worth looking into...
Old Jul 30, 2008 | 10:39 AM
sng302's Avatar
sng302
I brought home a multimeter from work 2day. I found that the ignition post (black I) on the solenoid is hot all the time. Not good . The old one went back in, all OK.
I thought buying the $30 selinoid w/ correct markings would get me better quality control. I'm not trying to win any tropies but do like to replace parts as close to original looking as possible.
Will exchange part @ CJPony Parts.
Old Jul 30, 2008 | 12:43 PM
kalli's Avatar
kalli
Hiya. check where the "i" post is going to
"i" is actually the one on the right. "s" for starter is on left.
The cable on "I" should go to your coil+. The only reason it is there is that when you start the engine it will feed 12V+ to your coil (instead of the 7.5 it usually runs with"). Since you have the old selonoid in I cannot tell you what to test.
Hope it works fine for you.
Any problems let us know and we'll check
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
drumhedd2005
Aug 13, 2015 09:59 AM
yurizx6r
Aug 11, 2015 07:50 AM
