68 Mustang
Old Aug 2, 2008 | 06:07 PM
ozz's Avatar
ozz
Default 68 Mustang
Hey I am over from the 5.0 section. My father has located a 68 mustang through a friend. Some old lady has it parked in her garage with stuff piled on top of it. The condition of it is unknown at this point. I know it has a 289. I don't know whether it is a fast back or not. I know it was running 10 years ago when it is parked. I have yet to look at it but my father and I are going to try and get it for like 1500. I had some general questions though. How much horsepower did the 289 make? What carb? I know there is a 4 speed manual and a 3 speed automatic? What transmissions are those 2. What size rear and what factory gear sets? Basically general stuff or if there is a good website for info I would appreciate the help.
Thanks guys.
Old Aug 2, 2008 | 06:09 PM
1slow67's Avatar
1slow67
ROTM Moderator
Default RE: 68 Mustang
www.mustangspecs.com
Old Aug 2, 2008 | 06:11 PM
1965fastback's Avatar
1965fastback
If it is a fastback it will be a steal for 1500.
Old Aug 2, 2008 | 06:14 PM
ozz's Avatar
ozz
The only real question that didn't answer of mine was what factory rears? I assume all v8s had disc brakes? Is the automatic any good? Can it stand power? How would a c4 fit in?
Old Aug 2, 2008 | 06:34 PM
1slow67's Avatar
1slow67
ROTM Moderator
Disc was an option. So it will most likely come with drums. It really depends if you like auto cars. My 67 is a 3 speed manual. It can stand the power. A C4 should fit with no trouble, I would go with the T5 if possible.
Rear ratios
1 > 2.75:1
2 > 2.79:1
4 > 3.83:1
5 > 3.00:1
6 > 3.20:1
7 > 3.25:1
8 > 3.50:1
9 > 3.10:1
E > 3.00:1 (limited-slip)
F > 3.20:1 (limited-slip)
G > 3.25:1 (limited-slip)
H > 3.50:1 (limited-slip)
Old Aug 2, 2008 | 06:35 PM
ozz's Avatar
ozz
So a c4 is a direct swap in?
Old Aug 2, 2008 | 06:39 PM
1slow67's Avatar
1slow67
ROTM Moderator
ORIGINAL: ozz
not sure about that. Hopefully some of the other classic people will know.
Old Aug 2, 2008 | 07:12 PM
tomnardozza's Avatar
tomnardozza
it's a 1968 1/2 cobra jet 428 fastback.....she offered it to me for 1200 but it had a dent on the roof from the stuff on top of it so i didn't buy it
Old Aug 2, 2008 | 07:23 PM
davesanborn's Avatar
davesanborn
Yeah, roof dents suck! You're better off passing on it. The 68.5 CJ cars are everywhere...
To the OP, not only is the C4 a direct swap, it's the standard factory transmission for an automatic car with a SB motor. If the car was a big block (FE motor), they'll be a C6 behind it.
The 4 speed manual trans in '68 would be a toploader and is pretty much indestructable.
Unless rust has taken ahold of her real bad, $1500 would be a very good price.... running or not.
Dave
Old Aug 2, 2008 | 07:25 PM
LCC's Avatar
LCC
ORIGINAL: tomnardozza
I call BS...
