8" Rear End Question
Old Sep 2, 2008 | 09:08 PM
hazzo1's Avatar
hazzo1
Default 8" Rear End Question
I have a 8 inch rear end in my '68 with an open diff......Is there anything holding the axles in the housing other than the third member? Like a retainer next to the drum?
Let's say I break an axle shaft, will the wheel and a portion of the axle shaft come out of the housing?
Thank you in advance.....I tried a search on here and on Google and I failed to find what I was looking for....
Old Sep 2, 2008 | 09:10 PM
racin66coupe's Avatar
racin66coupe
their held in with C clips. yes, if you break an axle it will do into your body. you can get a c clip eliminator kit from moser i think. i know someone makes em
Old Sep 2, 2008 | 09:59 PM
67mustang302's Avatar
67mustang302
8" don't have c-clips. They have a bolt on retainer at the end of the axle housing tube. If you break an axle, it'll vibrate and rattle all over the place, but should stay in. C-clip eliminators are designed to mimic the way 8" and 9" axles are held in place. Most 8.8's are c-clip though.
Old Sep 2, 2008 | 10:02 PM
Starfury's Avatar
Starfury
Yeah, vibrate, rattle....and not go anywhere A broken axle with an open diff means your car isn't moving under its own power.
Old Sep 2, 2008 | 10:09 PM
racin66coupe
do they realy? oops, my bad
Old Sep 2, 2008 | 10:15 PM
65Coupester's Avatar
65Coupester
The retainer holds the bearing that is pressed on the axle.
A broken bearing is another story. You can lose the axle then.
Old Sep 2, 2008 | 10:16 PM
67mustang302
Broken axles are bad either way. At least with a retainer it stays in(mostly) and you can keep control of it. It can still tear up the rear brakes on the side if fails though. Still, a lot better than having the axle go flying off into Never Never Land with your wheel, sending you into the wall.
Old Sep 3, 2008 | 12:17 AM
remicks's Avatar
remicks
Yup I know from experience 9" is the same as the 8". It's held in by the bolts by the bearing. But I ripped the splines off of my axles and blew up my spider gears and they stayed in just fine. Thank god it was my truck too because I just put it in 4wd and finished driving home.
Old Sep 3, 2008 | 04:49 PM
hazzo1's Avatar
hazzo1
Thanks a ton for the information! I won't be so paranoid when I drive my car now with the new motor......
Old Sep 3, 2008 | 05:15 PM
kalli's Avatar
kalli
aye. usually you have made mush out of any u-joint before the axle breaks i'd say
GimpyHSHS
Aug 29, 2015 06:30 PM
91StangOwner
Aug 20, 2015 11:34 PM
Black_GT_02
Aug 20, 2015 01:26 PM
ding56
Aug 14, 2015 02:40 AM
92 5.0stang
Aug 13, 2015 06:46 AM
