347 Stroker build
Old Oct 2, 2008 | 01:19 PM
kalli's Avatar
kalli
international ??? how much would shipping be to Ireland/Europe ? any ideas?
don't have the money for an engine, but I would really be interested to know.
Helps me dreaming you know ....
Old Oct 2, 2008 | 04:26 PM
sbertram's Avatar
sbertram
I've been doing some more research and I understand the pro's and con's for the 347 compared to the 331. In saying that I haven't decided exactly what I am going with. I am using a 4 speed toploader and going with the 91 block so what balance will i need the 28oz or 50oz??
Old Oct 2, 2008 | 07:56 PM
JMD's Avatar
JMD
Smile
28 - 50- - 0
Not for sure with a 347 or 331, but witha 351 based stroker, it all depends on the kit (or parts) used.....
Probably the same for 331/347.
If you intend on building your own stroker, you can select all of the parts seperatly, or you can save some money and a lot of headaches by buyimg a kit. And as long as you are buying a kit, make sure you ger a balanced kit.... it is worth the money and will save you agrivation.
Well, as long as you are buying a kit, you may as well just buy an assembled short block, I mean really, if you shop around, you can probably get an assembled short block for a little less than you can but all of the stuff and machine work to make your own....
And as long as you are doing this, check on the long block prices....... or the complete engine....
Old Oct 2, 2008 | 08:01 PM
racin66coupe's Avatar
racin66coupe
the only problem with a crate engine or even a longblock is you may not get the heads/cam/intake you may want for the power you want to make...
Old Oct 2, 2008 | 09:07 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
the only reason for doing a 331 is if you want less hp!! 347 ftw, the myths about the one vs the other is just that, I've been running my 347 for almost a 8 m onth and I run it hard and no issues or wear......I laugh everytime I READ the ole rod rational theroy, if that were more so true there are plenty of sbc's that have far worse rod rationale straight from the factory such as a 454 ??? anyway believe what you may but don't fear a 347, built right just like any motor , they don't burn oil or wear out as fast as one thinks, got a few customers with close to 100k on their d/d 347's
Old Oct 2, 2008 | 09:39 PM
lrgnation's Avatar
lrgnation
And to answer your balancer 28-50-0. Well 0 would be best because that means you internally balanced every part so external balancing is not needed. This is the best method however can cost a lot more but well worth it when spinning to higher rpm. (will allow more rpm)
svfetter
Oct 5, 2015 11:39 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
Brett Ludlow
Sep 23, 2015 06:59 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
