My Problem Sounds Like This
Old Oct 2, 2008 | 11:08 AM
adr3naline's Avatar
adr3naline
Default My Problem Sounds Like This
This should be good... I'm going to describe my sound and what my Mustang does, and I hope you can direct me or guide me to where to start....
So, my mustang lurches forward when I have it in drive and I'm moving forward slowly. The engine rev's up a little bit, and unless I have my foot on the brake, it'd really just jump. It only happens in drive, and only when the car first turns on (until it seems to warm up a bit), and only at slow speeds...
Where should I start? Is there more information you need to know?
Old Oct 2, 2008 | 12:03 PM
racin66coupe's Avatar
racin66coupe
check the idle....
Old Oct 2, 2008 | 12:13 PM
adr3naline's Avatar
adr3naline
The jumping doesn't just happen once, it happens multiple times... Are you just saying to adjust the carb?
Old Oct 2, 2008 | 12:32 PM
retro77's Avatar
retro77
anyway you could post a video?
I am thinking that the car is supposed to move forward slowly in Drive with no pressure on the brake.
Old Oct 2, 2008 | 01:40 PM
racin66coupe
it is supposed to move some.. but they way you describe it, it really tries to go on you.. do you have a tach? whats the idle set at?
Old Oct 2, 2008 | 02:23 PM
adr3naline's Avatar
adr3naline
I have a testing tach, so I'll hook it up tonight to find out. But if my idle was set high, would it cause it to jump? I mean it jumps, and slows down, then jumps, and slows down... it'll keep that up for a while till the engine is hot.
Old Oct 2, 2008 | 06:13 PM
Stepman's Avatar
Stepman
Check trans fluid?
Old Oct 2, 2008 | 08:09 PM
1slow67's Avatar
1slow67
ROTM Moderator
My 67 does that. I gun it and then go back to neighborhood speeds and it stops. It doesn't bother me a bit. Only does it when it is cold outside.
Old Oct 2, 2008 | 09:49 PM
Joe67's Avatar
Joe67
Banned
i would check trans fluid first, maybe converter not full?
musnicki
Sep 23, 2015 07:11 AM
MustangVixenGT
Sep 16, 2015 04:16 PM
5.0 kevo
Sep 3, 2015 06:24 PM
5.0pntydrpr
Aug 27, 2015 10:26 PM
