EFI kits? Any reccommendations?`
Old Oct 28, 2008 | 12:03 PM
  #21
RGH69's Avatar
RGH69
I would like to do the same thing. I can't find the Professional Products systems pricing anywhere. Do you know how much the multiport systems cost?
Old Oct 28, 2008 | 12:24 PM
  #22
69FB's Avatar
69FB
I think the Professional Products one is the Retrotek?
If so I saw where theirs is around 2800.00.
Not sure if that helps or not.
The retrotek looks like a carb so it can have fuel injection but still maintain the classic look.
Hope that helps.
Old Oct 28, 2008 | 06:00 PM
  #23
p25486's Avatar
p25486
The retrotek pricing is something like $2000, for the non-finished version. For $2800 you can get a nice shiney one.
Old Oct 28, 2008 | 06:03 PM
  #24
p25486's Avatar
p25486
I talked to a guy at a Fuel Injection shop here in Tempe AZ. They've only done Accel throttle bodies, with a full fuel return system. I'll be getting a quote soon.
I like the Retrotek thing cause it is cheap. I'm personally nervous that I'll mount the fuel pump, filters and line correctly and safely.
Old Nov 1, 2008 | 12:03 AM
  #25
p25486's Avatar
p25486
So, if I'm going to mount a fuel pump and filter near the fuel tank, where should they go? On the frame?
Old Nov 1, 2008 | 10:00 AM
  #26
68EFIvert's Avatar
68EFIvert
I mounted my fuel system on a fabricated bracket that is between the rear end and the gas tank. It puts them both close to the tank.
Old Nov 1, 2008 | 07:40 PM
  #27
LCC's Avatar
LCC
I personally like FAST and BS3 computers. You can do anything you want with them and there are tons of guys out there that can tune your setup if your not comfortable doing it yourself.
Old Nov 2, 2008 | 05:33 AM
  #28
67 evil eleanor's Avatar
67 evil eleanor
If you are into a lot of options, then the Accel will do the most. Like A/C control (cuts the compressor off at 80% WOT and will not restart untill you drop below 30% for like 15 seconds), dual fan control with A/C fan on, staged nitrous, boost control, low imp injectors, fuel pump control, about 100 screens of data logging. Its a great system and its what I have in the 5.4 67. Beefore you buy a system, list all the things you plan to have on the car and make sure the ecm is able to operate them.
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
Drastang
Sep 30, 2015 03:48 AM
