Turn signal help
Old Nov 24, 2008 | 08:38 PM
eZ's Avatar
eZ
Default Turn signal help
Talking about rear lights.
Both lights works when lights are on
right turn sgnal works
left does not
when braking only right side comes on
I thought it might be a problem with my sequential tail lights. Put a new one in and same problem. grounds are good. And it seems im getting power to the left socket when brakes are applied.
Old Nov 24, 2008 | 09:29 PM
djsprinklesnjo's Avatar
djsprinklesnjo
well how about this, my hazards work when i push the button in, all four blink,
however when i hit the turn signal switch nothing happens. i changed the turn signal switch. but still nothing.
Old Nov 24, 2008 | 09:57 PM
vescotech's Avatar
vescotech
djsprinklesnjo have you replaced the turn signal flasher? Possibly a cheap fix.
Old Nov 24, 2008 | 10:04 PM
vescotech's Avatar
vescotech
EZ use a test light to verify whether or not you have power when brakes are applied . If you don't then it's possibly a turn signal switch. I'm not familer enough with the sequential system to comment. Good luck
Old Nov 24, 2008 | 10:52 PM
eZ's Avatar
eZ
I tested and i do get power when the brakes are applied. However no matter what bulb i put in they do not work.
Old Nov 24, 2008 | 11:40 PM
az1966's Avatar
az1966
try checking the center post of the lite socket where the harness connects to the lite,,if the center post is mashed that causes some really weird isuess,,,dont't even ask me about that one,,ya I know its weird but as I said
Old Nov 27, 2008 | 11:43 AM
djsprinklesnjo
vescotech, you know what, i totally over looked that. ughh i feel so dumb now. thats why i can always count on this forum for help. thanks
also on a side note. a while back ive thought about rewiring the whole car with those aftermarket wire harness kits. and just never did it, now its almost winter again and i think ill look into doing it again. maybe ill try a universal kit. the painless ones are sooo overpriced.
jwog666
Dec 27, 2021 08:09 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
breaking
Oct 2, 2015 01:27 PM
ChampInSD
Oct 2, 2015 04:55 AM
logan409
Sep 26, 2015 07:43 PM
