Header Advice
Old Nov 27, 2008 | 07:10 PM
BeastMachine67's Avatar
BeastMachine67
Default Header Advice
Hey guys I had a question for those of your that have done a T-5 conversion to your 67-70 mustangs. What kind of headers if any did you use? I'm pissed because I bought a pair of hedman long tube headers that I was told would fit and instead they don't. The driver's side has no clearance for my clutch cable and my power steering lines. I'm almost about ready to give up and just go back to the stock cast-iron manifolds but, I thought maybe it would be best to get an opinion or some advice on which ones would go best with my car without putting a hole in my wallet. Any ideas would definately help.
-Thanks
Old Nov 27, 2008 | 09:50 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
i dont have a 69-70 but cars with p/s require a steering cylinder lowering bracket. as for the clutch cable post some pics you might just be able to get away with wrapping the headers to keep the cable cool etc. and sometimes a hammer can be your friend to put a few minor dimples in header tubes
Old Nov 27, 2008 | 10:49 PM
BeastMachine67
they were ceramic coated headers, I didn't want to bend or crack them in anyway. Besides there was absolutely no clearance for the clutch cable at all! which sucked! lol but, I dunno. I just wanted to have some headers but if it's gonna be such a pain to have them I'm thinking about going back to the old manifolds. that's why I wanted to know what everyone else was using for their t-5 setup.
Old Nov 27, 2008 | 11:34 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
you might want to look in to the hyd clutch setup a lot easier to work around headers. and its lower maintenance softer pedal more like a modern car. and then you just need the 15$ p/s lowering bracket http://www.mustangsunlimited.com/ite...atkey=EMUSTANG
Old Nov 27, 2008 | 11:56 PM
BeastMachine67
thanks but, I already bought the cable clutch kit so I wanna work with that
Old Nov 27, 2008 | 11:58 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
just a suggestion, since you already installed the header which im sure were pricey being ceramic it would probably in your interest to sell the clutch kit and go hyd my 2 cents
Old Nov 28, 2008 | 01:10 AM
Adrenolin's Avatar
Adrenolin
+1 to this. Keep the headers and go with the hydraulic clutch.
Old Nov 28, 2008 | 01:34 AM
BeastMachine67
isn't the hyd more expensive?
Old Nov 28, 2008 | 10:20 AM
Adrenolin's Avatar
Adrenolin
I spent between 200 to 250 for a hydraulic clutch setup that goes to our 4-speed toploader. I know there are hyd setups for the T-5 that you can buy in a kit. Cheaper than replacing ceramic headers. Do a search here and Google it.
If your going headers regardless of short/mid/long a hydraulic clutch is the best way to go.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Jb145700
Aug 21, 2022 06:37 AM
Luke9222
Oct 22, 2015 11:55 PM
junior04
Sep 28, 2015 10:53 AM
Shadow7874
Sep 24, 2015 09:06 PM
