rockers ajustment
Old Nov 27, 2008 | 10:08 PM
65Rocky's Avatar
65Rocky
Default rockers ajustment
I need to ajust the new 1.6 rollor rockers on the 5.0 in my 65, hyd lifters, harden push rods.alm heads
Is it tighten it until the rods will not turn, and lock it down.
Old Nov 27, 2008 | 11:39 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
when the lifter is at the bottom of its lifter bore you snug the adjustment nut hand tight until you can turn the pushrod in between you finger tips anymore. you then tighten it down 1/4 turn with the wrench then lock the nuts down. then move to the next rocker you will have to turn the motor over to do all them as you move down the line
Sixer4Life
Oct 12, 2015 04:26 AM
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
uedlose
Sep 30, 2015 08:01 AM
Sixer4Life
Sep 28, 2015 07:05 AM
JDWalton
Sep 24, 2015 08:47 PM
