How do you put a 289 engine in
Old Dec 7, 2008 | 02:47 PM
jonm1a1's Avatar
jonm1a1
Default How do you put a 289 engine in
When you are putting in a 289 engine into a automatic tranny thats in the car do u install the torque converter on the motor 1st or on the tranny 1st
Old Dec 7, 2008 | 02:57 PM
jonm1a1's Avatar
jonm1a1
Default ok i am a clown
I searched through the post and found my answer!!!! imagine that
Old Dec 7, 2008 | 03:11 PM
fakesnakes's Avatar
fakesnakes
TC to the tranny, then engine to the tranny, then TC to the engine flexplate.
Old Dec 8, 2008 | 05:27 PM
groho's Avatar
groho
Hey Sgt, pay attention when you install the converter on the tranny. As you put it on the shaft, turn it. you feel it drop, then drop a second time. Also, make sure the converter drain plug lines up on the flywheel hole as you bolt up the converter and flywheel. If you're unable to smoothly bolt everything together, don't force it. stop, turn the converter and try again.
djbigskrilla
Sep 20, 2022 01:04 AM
kdryan
Aug 21, 2015 04:01 PM
Philhampton1
Aug 21, 2015 12:04 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
ding56
Aug 14, 2015 02:40 AM
