How will I sit?
Old Jan 11, 2009 | 02:57 AM
jonward786's Avatar
jonward786
absolutely nothing if you live in an area with beautifully paved smooth roads. but for you and me living in slo where the roads are like @ss, 620s would rattle his teeth out of his head.
i was gonna get 620s until Tad made me realize how ****ty slo roads are, my car rattles enough as is lol
Originally Posted by 4reboy
what's wrong with the 620's? I've heard this a few times and have always wondered...
Old Jan 11, 2009 | 08:11 AM
dodgestang's Avatar
dodgestang
Nothing wrong with the 620s if you are building a race car they are very stiff. They still ride very very stiff on the street in my 65 and I have the extra weight of a Cleveland on top of them. I was able to soften up the ride a little bit without giving anything away with the addition of the IAS shocks. In my 67 which I am building in a similar vain as the 65 I am not using the 620s. I am simply putting the big block springs in and will trim to the height I want.
Old Jan 11, 2009 | 09:59 AM
69mach1377's Avatar
69mach1377
Originally Posted by 350kmileFord
OK.
Now for sway bars? I'm going to get a front setup now, but will deal with a rear setup later; so we don't need to go into that.
Will I be satisfied with the 1" or should I go with the 1 1/8"? Only ten bucks more. I assume it will handle better, how else will the ride differ?
1" is plenty unless you are competing...
Old Jan 11, 2009 | 11:01 AM
Carlos Pineiro's Avatar
Carlos Pineiro
I seem to remember stock coils on 65-68 being 480 lb. Anyone know for sure?
Also, I helped restore a few gen 1 mustangs that had 3/4" sway bars. Was this a dealer option back then, or was it just an old standard size aftermarket part people used 20 and 30 years ago?
Just curious. I like Mustang history.
CP
Old Jan 11, 2009 | 11:56 AM
fakesnakes's Avatar
fakesnakes
You might even want to go with a 7/8" sway bar. You don't have enough weight in the front and with heavier springs, it will be fine.
Old Jan 11, 2009 | 12:14 PM
Starfury's Avatar
Starfury
I agree, GT springs (cut if needed), Shelby drop, and 7/8" or 15/16" front sway bar. Stiffer springs or a larger sway bar will make the front end of your light I6 car extremely stiff.
Old Jan 11, 2009 | 02:18 PM
350kmileFord's Avatar
350kmileFord
CP
Mustangs Plus has 2 stock V8-application springs listed for the 65-66:
http://www.mustangsunlimited.com/ite...p?T1=CS8090+01
http://www.mustangsunlimited.com/ite...p?T1=GT2670+01
235 lbs./in and 480 lbs/in used on the Gt and Shelby Gt 350 models.
Does 235 sound a little soft to anyone else?
Old Jan 11, 2009 | 02:30 PM
Starfury's Avatar
Starfury
235 sounds like I6 springs. 480 is the GT spring rate, and I believe stock 289 springs were about 360
Old Jan 11, 2009 | 06:41 PM
Carlos Pineiro
The vendor in the link lists the 235 coils as: "Application 1965-1966 289 w/ or w/o air"
That could be MU making a mistake or just marketing them to their own satisfaction. Or it could be correct. Either way, it doesn't sound like a sufficient stiffness for fast, bad roads. When you have a 289 2bbl with polyglass tires, no one is taking turns at high speeds so maybe that's why 235s seemed OK.
CP
Old Jan 11, 2009 | 08:18 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Also, I helped restore a few gen 1 mustangs that had 3/4" sway bars. Was this a dealer option back then, or was it just an old standard size aftermarket part people used 20 and 30 years ago?CP
I believe the factory GT sway bars were 13/16.
baddog671
Jul 26, 2016 01:20 PM
treesloth
Sep 28, 2015 07:03 AM
mrappe
Sep 26, 2015 10:16 AM
col2560
Sep 25, 2015 06:51 AM
96stang3.8
Sep 10, 2015 06:42 AM
