coil spring installation safety question
Old Jan 20, 2009 | 12:17 PM
blue289's Avatar
blue289
Default coil spring installation safety question
Will the coil spring really stay on the spring seats without the shock installed? Is it safe to be working around the spring in this condition? I am afraid that when I install the shock the spring could slip out of the seats.
I have loosened the struts and detached the sway bar to allow the control arms to drop as much a possible so I do not have to compress the spring as much. Should I tighten the struts and reconnect the sway bar to give the control arms plenty of support while holding the spring in place?
Old Jan 20, 2009 | 12:33 PM
dcohen's Avatar
dcohen
they are fine, my springs have been in place without the shocks for a a long time while i have been working on my car
Old Jan 20, 2009 | 12:35 PM
Starfury's Avatar
Starfury
Yes, it is safe to have the shocks out while working around the suspension. The stock springs will stay firmly in place. Even if you have drop springs, by the time they get loose enough to rock out of place, they won't have enough tension on them to go flying anywhere, they'll just fall out.
You can't remove the springs without removing the shocks (there are no 'struts' on the car), so leave everything disconnected.
Old Jan 20, 2009 | 12:42 PM
blue289's Avatar
blue289
Thanks for the help.
Old Jan 20, 2009 | 10:20 PM
JERM_1967stang's Avatar
JERM_1967stang
or if your scared wrap a chain around one of the top coils and bottem coils like they used to to drop low riders way back when. that will keep it compressed with no chance of it shooting anywhere.
drfister
May 3, 2018 10:38 PM
spectreman
Mar 31, 2016 09:26 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
ding56
Aug 14, 2015 02:40 AM
Pain.
Aug 7, 2015 10:48 PM
