Cam - Question
Old Jan 27, 2009 | 07:09 AM
gwb16's Avatar
gwb16
Originally Posted by kalli
and from what I read you don't have to bother with looking for high zinc oils
Kalli
Or you could use this..... http://www.zddplus.com/index.htm
Old Jan 27, 2009 | 09:06 AM
mstg007's Avatar
mstg007
Whats the best way to clean roller lifters? or.... buy New ones?
Dump Dump... lol more $$$$
Old Jan 27, 2009 | 11:19 AM
kalli's Avatar
kalli
i actually thought tou don't need any of those with roller cams. flat tappet only requirement.
Could be wrong though
Old Jan 27, 2009 | 11:30 AM
Norm Peterson's Avatar
Norm Peterson
I think gwb's comment was directed more at how to live with a flat-tappet cam as an alternative to going roller.
Norm
Old Jan 27, 2009 | 12:43 PM
Starfury's Avatar
Starfury
How 'dirty' are they? You should be able to clean them out with carb cleaner or chem-dip.
Old Jan 27, 2009 | 12:55 PM
mstg007's Avatar
mstg007
They just look alittle dirty. Brownish. I will degrease them and see how they look!
Old Jan 27, 2009 | 01:09 PM
Starfury's Avatar
Starfury
Carb cleaner or Chem-Dip should work fine. Don't use a wire brush.
Old Jan 27, 2009 | 02:00 PM
my77stang's Avatar
my77stang
if you want to do it right, you need to disassemble the lifters and clean them. here's some pics of my flat tappets that i did, the guts are basically the same - as is the procedure. with a roller cam you do not need to worry about keeping each lifter in order and the guts will interchange without a problem.
just pop the little retaining clip out and the guts should all come out of the lifter. then clean in gas/carb cleaner/whatever your using. when you reassemble you just squeeze the guts down in a vice and pop the clip back in. when your all done you should be able to take a pushrod, push down on the lifters and they should be springy/squishy.
Old Jan 27, 2009 | 02:52 PM
gwb16's Avatar
gwb16
Norm
Thanks Norm, that's exactly what I meant. I use that stuff in my 302 (flat tappets). No problems to date....somebody find me some wood to knock on please!
Old Jan 27, 2009 | 03:21 PM
mstg007's Avatar
mstg007
Sounds good. My lifters dirty color look like yours. I wil ltry to pull apart and clean them up! Carb Cleaner!
Luke9222
Oct 22, 2015 11:55 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
