Cap and Rotor Question
Old Mar 3, 2009 | 01:45 PM
Toddman0025's Avatar
Toddman0025
Default Cap and Rotor Question
I have an unknown distributor with a Mallory Unilite ignition module inside. I'm looking to replace my cap/rotor and was wondering if I can just get a generic cap and rotor, or do I need to figure out what kind of distributor I have?
Can the Unilite module ever go bad?
Trying to diagnose my weak spark issues...
Thanks!
Old Mar 3, 2009 | 03:05 PM
urban_cowboy's Avatar
urban_cowboy
I had issues with two concurrent Mallory Unilite dizzys. I would accationally just loose spark and would have to jiggle wires and pull the connections to the MSD ignition and reconnect. I never did really find out what was wrong, but after I got stranded for an hour, I bough a MSD dizzy. I have had zero issues with my MSD dizzy, so take that for what it is worth.
Old Mar 3, 2009 | 03:21 PM
Starfury's Avatar
Starfury
That said, a consistently weak spark by itself is probably not going to be a result of the module going bad. All the module does is tell the coil when to fire, so when a unit goes bad it usually results in either improper/erratic ignition timing or no spark at all.
Bring your cap/rotor into your favorite auto parts store and see if it's the same as a standard Ford setup. I bet it is.
Old Mar 3, 2009 | 03:28 PM
Toddman0025
Are you also running a MSD 6 ignition and MSD coil ?
I was thinking about just scraping all the Mallory equipment anyway...
Old Mar 3, 2009 | 03:41 PM
Starfury's Avatar
Starfury
I'm running an MSD Pro-Billet ready-to-run distributor in my 331 and I'm happy with it. No box yet, but it's a plug-in addition later on when I can afford it. I've got my eyes set on a Digital6 box.
Oct 7, 2015 07:02 PM
Omgitsa88Stang
Oct 5, 2015 07:33 AM
Sep 16, 2015 07:53 PM
Wombatnation
Sep 13, 2015 09:16 PM
96stang3.8
Sep 10, 2015 06:42 AM
