Timing Question - Dealing with Balancers
Man that is a lot of trouble just to figure out if the dizzy is 180 out. Pull the valve cover on the passenger side and rotate the engine until both valves are closed on #1 and the piston is at the top. Look at the timing mark on the damper and rotate the engine until in is right on 0deg. That is TDC. Drop your dizzy in pointing at the #1 plug wire. Done, easy. No special tools. No rocket science.
Urambo Tauro
Aug 27, 2015 10:53 AM
