drive shaft problem in a t-5 conversion
I have a 66 Mustang that used to have a c-4 transmission in it. I'm currently in the middle of installing a t-5 out of a 93 Mustang. I bought a slip yoke for a t-5, but I realized today that it uses a u-joint with an outside snap ring, but the driveshaft I have from the automatic car needs an inside snap ring. The worst part is if I replace the driveshaft I'll end up with the same problem at the rear. The old automatic slip yoke fits on the transmission, it would just have to be shortened by about an inch. Would this cause a problem? I'd love to talk to someone who's done this before. Thanks.
+1 I did the c4 to t5 swap and my stock driveshaft and yokes fit. It was a little tight, but was go0d enough until I could save up for a new shaft.
Stop guessing how much free play and such you should have. With weight on the rear wheels, measure the length from the back of the trans tailshaft to either the center of the u-joint cup on the pinion yoke or the back of the u-joint cup on the pinion yoke. Give that measurement to a driveline shop and let them do the adjustments for you, thats what they get paid to do.
Oh and one more thing before I forget... If your t5 is not brand new or has more than 0.01 miles on it (in someone else car) after a rebuild, pull the tail shaft case off and replace the bushing inside and the oil seal before you install it in the car if its not too late. IF only take one bit of advice at least make it this as parts are nearly free...3 bucks worth i think.
-Gun
-Gun
Gary Ugarek
63
Dec 11, 2015 02:01 PM
