PCV Modification 1988
Old May 8, 2009 | 10:14 PM
Grayrage's Avatar
Grayrage
Default PCV Modification 1988
I have a 1988 stang w/ some issues. It has had a lot of performance work done Holley injection holly heads stroked etc.... anyways guy who did the work did not finish the job and cannot be found. So... here is my first problem
Noticed there was oil in the intake, checked the oil level... ok saw that there was no PCV valve.. it has aftermarker valve covers and there is only one nipple coming off of the cover... How is air supposed to flow in and the pcv valve let air out with one fitting??? An oil cap with a breather?
Old May 8, 2009 | 10:18 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
first off welcome to the forum
second you're in the wrong forum section :P
the answer to your question\/
the PCV valve is at the rear of the lower intake manifold
the 5.0 sections are here https://mustangforums.com/forum/5-0-mustang-14/
https://mustangforums.com/forum/5-0l...discussion-87/
Old May 8, 2009 | 10:24 PM
Grayrage's Avatar
Grayrage
oh whoops thx this setup appears not to have that but ill double check
Old May 8, 2009 | 10:26 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
does your setup still have the EFI??
Old May 9, 2009 | 12:44 PM
Grayrage's Avatar
Grayrage
Yes it does.
Vrooom
Feb 21, 2016 05:25 PM
lmurf60
Sep 24, 2015 10:07 PM
Ipaman
Sep 22, 2015 07:01 AM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
