Oil pump question????
Old May 22, 2009 | 05:59 PM
TexasAxMan's Avatar
TexasAxMan
Default Oil pump question????
I'm about to assemble my first Ford engine. Looking at the HD oil pump driveshaft I got, it cam with a part I don't know where it goes. I looks like a sheetmetal nut, Where does this go????
Any help appreciated.
Old May 22, 2009 | 07:53 PM
2+2GT's Avatar
2+2GT
Extremely important part! With the pump installed, install the shaft with the flat end down, and the pointy end toward the top. The pushnut should be installed with the cup side up, as close to the top as it will go. This pushnut keeps the drive shaft from coming out if you remove the distributor at some point.
Old May 22, 2009 | 08:08 PM
fakesnakes's Avatar
fakesnakes
It will only move on the shaft in one direction. Slide it up the shaft from the bottom, but stop just short of the hole the shaft extends through at the top. You do not want it to rub on the block as it spins.
Old May 22, 2009 | 09:45 PM
67mustang302's Avatar
67mustang302
Once the pump is installed with the shaft, you should have some up and down play of the shaft, and that retainer should keep the shaft from coming out, but yeah, you don't want it so tight that it always contacts the block.
raleigh05GTO
Sep 4, 2015 07:09 AM
cbird1177711
Sep 3, 2015 08:43 PM
5.0 kevo
Sep 3, 2015 06:24 PM
cbird1177711
Sep 2, 2015 08:51 PM
