Secondaries
Old May 23, 2009 | 08:28 AM
redzo6's Avatar
redzo6
Default Secondaries
Hello all, I just picked up a 70 Mach with a 351c and a holley 4 barrel. I am trying to figure out why the previous owner did not have the secondaries working. The car was not a daily driver but a monthly driver, so I know its not a fuel issue.
Thanks for any input.
Old May 23, 2009 | 09:12 AM
2+2GT's Avatar
2+2GT
How did you figure this? Is the rod disconnected? I can't think of why this would be done, unless he had teenage children.
Old May 23, 2009 | 09:26 AM
fakesnakes's Avatar
fakesnakes
Perhaps a mistaken attempt to increase gas mileage? How do you know they are not working? If you post pictures, we can help you fix it.
Old May 23, 2009 | 12:00 PM
1sweet65stang's Avatar
1sweet65stang
maybe he didnt know that they werent able to be opened because the throttle rod was too long enough etc.
Old May 23, 2009 | 12:18 PM
redzo6's Avatar
redzo6
Thanks for everyones help, The problem was the vacuum secondaries spring was way to strong not allowing it to open up. Thanks all.
Old May 23, 2009 | 06:24 PM
kalli's Avatar
kalli
the PO probably never knew ... wouldn't surprise me
or you tried it in idle just revving up. they shouldn't open there (no load).
Do you know from driving they don't open up or did you test it at idle?
Old May 23, 2009 | 06:34 PM
Gun Jam's Avatar
Gun Jam
you can use the paper test method to figure out if they are working...
Place the small sheet of paper with a hole in it so it can be placed on the plunger rod. Place it so its flush with the base of the 2nd mechanism...If the 2nd activate it will force the paper down the rod.
-Gun
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
trashxtrash
Sep 20, 2015 10:49 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
dochawk
Aug 25, 2015 08:25 AM
TheGmKiller331
Feb 16, 2004 07:16 AM
