'68 Autometer gauge setup...
Old Jun 8, 2009 | 08:43 PM
Venomus68's Avatar
Venomus68
Default '68 Autometer gauge setup...
For my '68 Shelby I decided to go with some autometer Ultra-Lite's. I got a tachometer, spedometer, volt, water temp, oil pressure, vaccum, fuel gauge. The water temp, fuel, and volt are going to go on the bezel and the vaccum and oil pressure are going to go on the windshield pillar. I would have put the tachometer and spedometer in but I thought it was a 3 3/8. What size are the tach and spedometer? I have figured out away to mount the gauges to this aftermarket bezel but am confused on what this piece is supposed to do for cars with aftermarket bezels? Besides that they look amazing and i'll be ready to go once I return the other gauges. I also purchased a flaming river steering column from ebay for about $475 with all of the joints. I went with the leccarra wood wheel but it was on back order (($375 from Summit) hopefully it should be here sometime this month.
Old Jun 8, 2009 | 08:45 PM
1slow67's Avatar
1slow67
ROTM Moderator
They should be 5" gauges.
Old Jun 8, 2009 | 09:38 PM
Venomus68's Avatar
Venomus68
Does anyone have any idea what that plastic adapter for autometer gauges does?
Old Jun 9, 2009 | 07:55 AM
boeing747arowair's Avatar
boeing747arowair
which one? the one that goes on the back held on with two nuts?
Old Jun 9, 2009 | 02:39 PM
Venomus68's Avatar
Venomus68
this peice
Old Jun 10, 2009 | 12:20 AM
67t5ponycoupe's Avatar
67t5ponycoupe
I've got some pics that might help. I put Autometers in my 67. I started with a new bezel and the old gage cluster. I used the stamped steel backing from the old gage cluster to mount the new Autometers in to. Also used the old wiring that need to be modified.
Attached Thumbnails '68 Autometer gauge setup...-dsc02279.jpg   '68 Autometer gauge setup...-dsc02278.jpg   '68 Autometer gauge setup...-dsc02277.jpg   '68 Autometer gauge setup...-dsc02276.jpg   '68 Autometer gauge setup...-dsc02275.jpg
Old Jun 10, 2009 | 12:24 AM
67t5ponycoupe
The holes in the stamped steel backing from the original had to be cut out bigger to accept the larger gages. Them I made L brackets to attach the gages to the backing. The Bezel also had to be carved out some on the back where you can't see it to get the Speedo and Tach to fit. I think you can see most everything you need to in the pics.
Old Jun 11, 2009 | 06:46 AM
Venomus68's Avatar
Venomus68
Thanks! I ordered the wrong gauges and shipped them back yesterday my new ones should be here next wednesday or so. I got the 3 3/8 not the 5".
jwog666
Dec 27, 2021 08:09 PM
andrew1969
16
Jan 8, 2016 02:48 PM
SteelerNation82
Sep 16, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
