Upholstered lower dash
Old Jun 18, 2009 | 09:47 PM
Green69's Avatar
Green69
I forget what I used this trick for, but if you find a bad bubble and can't peel off to try again.. put some adhesive into a tiny syringe and squirt it into the bubble. My father was a doctor, so it was easy for me to get a small needle. These days you would need a prescription from your physician, I guess.
Old Jun 18, 2009 | 10:47 PM
Adrenolin's Avatar
Adrenolin
Originally Posted by flickjo68
I think it looks great. At first I was unsure of how it would turn out when you mentioned it in another thread. It looks almost like it could be factory. Kinda one of those things that when you see it at a show you're like "Is there something different about that dash?" lol.
Its a fairly easy thing to do. Must have a second person there to help. I started drivers side and had a buddy on the passenger side holding the other end up as i guided, lightly stretching and pressed it on. Section it off by applying spray adhesive from drivers side to between ashtray/radio, then over to glovebox, then finish it off. Leave the end wrap around till after you do the sections. You'll need some contact cement afterwards to get the lower edges, etc.
No bubbles at this point but yes, your correct in this trick.
lincolnshibuya
Jul 5, 2020 03:05 AM
lincolnshibuya
Oct 6, 2015 08:45 AM
Urambo Tauro
Oct 5, 2015 09:37 PM
UrS4
Oct 3, 2015 06:23 AM
breaking
Oct 2, 2015 01:27 PM
