will not start
Old Jun 22, 2009 | 08:59 AM
65Rocky's Avatar
65Rocky
Default will not start
I am getting a strong rearend oil smell in the engine area, I did checked the rearend nothing, when I turn the car over I get click click,battery is alright I even attemted to pump it no luck.
Is the starter getting to hot???
Old Jun 22, 2009 | 09:32 AM
dcohen's Avatar
dcohen
what are you talking about?
have you checked to see if the battery is any good?
if it is not that then the solenoid might be bad
Old Jun 22, 2009 | 09:51 AM
2+2GT's Avatar
2+2GT
Originally Posted by 65Rocky
I am getting a strong rear end oil smell in the engine area, I did checked the rear end- nothing, when I turn the car over I get click click,battery is alright I even attemted to pump it no luck.
1) Did you check the level of the gear oil in the rear?
2) Clicking solenoid can be low battery charge, fried solenoid, loose cable connection between battery and starter, or bad starter. Start at the battery end and work your way toward the starter.
Hot starters run slow.
Pumping will simply flood the engine with gasoline.
Old Jun 22, 2009 | 01:03 PM
65Rocky's Avatar
65Rocky
Fried Starter guys thanks, now I know what that smell was LOL
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
dalefrancis88
Sep 11, 2015 07:15 AM
5.0 kevo
Sep 3, 2015 06:24 PM
