Parking Brake hookup - underside
Old Jun 24, 2009 | 06:39 PM
Flash70's Avatar
Flash70
Well mine isnt as clean as 2+2 but its for a 70 so here it is
Old Jun 24, 2009 | 10:21 PM
4reboy's Avatar
4reboy
sweet those are great, thanks!
Old Jun 24, 2009 | 10:41 PM
jonward786's Avatar
jonward786
Originally Posted by Starfury
You don't want it to roll down a hill into my car.
YES I DO
Old Jun 24, 2009 | 11:04 PM
Cruzzar's Avatar
Cruzzar
Here's a pic that should help. This is on my '70FB, it should be the same.
Old Jun 25, 2009 | 03:30 AM
4reboy's Avatar
4reboy
wow, Cruzzar you're awesome. Is yours welded in or no? Looks like its just bonded on or something, unless I'm blind and don't see the welds. Thanks for those measurements though!
Old Jun 25, 2009 | 06:07 PM
Cruzzar's Avatar
Cruzzar
It has the factory spot welds on each of the three ears that mate to the bottom of the floor pan. You're right, I can't see them either but they are there.
Old Oct 31, 2011 | 01:23 PM
armymach1man's Avatar
armymach1man
Default Idler Floor Bracket
Does anybody know if the measurements the same for a '73 Mach 1? I have the same issue with my car. Also, is there an idler bracket on the left hand side under the driver's side floor pan? I understand the cable routes through the frame rail but I ran into something about a left hand idler bracket.
Old Nov 1, 2011 | 05:21 AM
2+2GT's Avatar
2+2GT
I moved one on a 67 last summer on a fully assembled car. I pulled the RH seat, lifted the carpet, shoved a small sheet of plywood between the floor and carpet/deadener, and welded it in the correct place. Which, BTW, is as far into the corner as it will go, without overlapping the metal tabs on the frame rail and crossmember. It should be at a 45° angle relative to the centerline of the car, so that the cable link points straight out.
The 69-73 had the front cable attached to a bracket on the LH side. The RH side was similar to the earlier brake.
Old Nov 1, 2011 | 03:03 PM
Couper's Avatar
Couper
Kinda hard to see can you get me a closer, clearer shot?
Old Nov 2, 2011 | 08:22 AM
2+2GT's Avatar
2+2GT
Closer than that would be a shot of the underside of the carpet.
Matt's 95 Stang
Oct 5, 2015 07:16 AM
breaking
Oct 2, 2015 01:27 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
