Rear leaf spring help 68 Coupe
Old Jul 3, 2009 | 03:54 PM
Jforte13's Avatar
Jforte13
Default Rear leaf spring help 68 Coupe
Hey guys, need some help. I am in the middle of replacing the rear leaf springs and all was going great actually untill the front bolt decieded to be stubborn. I got all the bolts/nuts off the back and middle. and i got the front nut off, and i can TURN the bolt from the inside of the frame area, but can't get it to come OUT to get the spring out.....how do i get the bolt out? There is NO room on the outside to hammer it out...please advise!! Thanks! James
Old Jul 3, 2009 | 04:06 PM
2+2GT's Avatar
2+2GT
The steel tube in the center of the eye bushing has rust-seized itself to the eye bolt. Cut across the eye in the spring with a cutoff wheel, so the spring eye comes off like a clamshell. Then cut through the eye bushing with a cutoff wheel, taking care not to damage the car frame. Once you've done this, a little tapping should be all it needs.
Old Jul 3, 2009 | 05:28 PM
Jforte13's Avatar
Jforte13
Wow this has become more of a production than i thought. At this rate, wouldn't it be easier to just cut the bolt with a hacksaw on each side of the spring? Then just get a new bolt for the new leaf spring?
Old Jul 3, 2009 | 05:43 PM
2+2GT's Avatar
2+2GT
Well, the $185 kit I mention occasionally comes with the bolt.
As to removing the bolt, good luck getting a hacksaw through a grade 8 bolt, especially with the hacksaw against the frame pocket. The blade will go through the frame like butter, but the bolt will murder the blade.
Old Jul 4, 2009 | 08:35 AM
Jforte13's Avatar
Jforte13
Thanks for your help. You have atleast saved me the aggravation of trying to saw through the bolt. I will take your advice on this, putting this project off to next weekend, and onto others that are much less complicated...
Old Jul 4, 2009 | 09:33 AM
onehollywood's Avatar
onehollywood
Try spraying some WD40 into the bolt and letting it soak for a while and then applying pressure using a C-clamp on the bolt. If it retracts thru the hole, that is the threaded portion unexposed, you can use a drift to punch it out.
I upgraded my rear leaf springs last month (visit my web site below signature block) and I had not much of a problem with the front bolts except that I had to use a drift to push out the bolts out of the frame as far out as possible and wrenching it off.
Old Jul 4, 2009 | 11:46 AM
MonsterBilly's Avatar
MonsterBilly
I JUST DID MINE. IT WAS NOT THAT DIFFICULT BECAUSE I USED A SAWZ ALL AND ABOUT THREE BLADES PER SIDE. THE TOTAL THING TOOK 1 HOUR FOR BOTH SIDES.
PullTab
Oct 30, 2015 08:46 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Sep 8, 2015 11:50 AM
