Leaf spring install question. Don't kill me :)
Old Aug 26, 2009 | 07:29 AM
scootchu's Avatar
scootchu
Originally Posted by kalli
i actually prefered to do one side after another. it feels safer. the car has still one wheel to stand on ...
That was my thought process. Nothing was "that" loose.
Thanks.
Old Aug 27, 2009 | 05:41 PM
65melondrive's Avatar
65melondrive
I always prefer to do one side at a time. That way you have something to reference when you put it back together.
This defiantly helps on more complicated procedures. Not such a big deal with swapping springs, but a good practice to use.
Old Aug 27, 2009 | 06:03 PM
HGC's Avatar
HGC
Originally Posted by rmodel65
no guy he has to do all 3 sides at once
Wrong. You have to do the third side after the second but before the first (unless it's Tuesday and Venus is aligned with Mars). If you do the second and third side at the same time it will cause the front branch springs to be out of alignment with the ignition preloader, and that will cause a singularity (a black hole) which will suck the entire car into the tailpipe.
You can find the step by step procedure in the February 1992 issue of National Geographic. It's right before the 30 page photo spread on the Hubcaps of Bolivia.
Geez, rmodel65, I thought you knew better.
Old Aug 27, 2009 | 06:06 PM
HGC's Avatar
HGC
Actually, your biggest headache might be that front bushing/bolt assembly. I have never done it but I hear that can be real stubborn. I would do one side at a time too.
Old Aug 27, 2009 | 08:43 PM
scootchu's Avatar
scootchu
Aaaaaaahhhhhhhhhhhhhhhh... yes. I did the front coils yesterday and what fun they were, but new springs and shocks make such a difference.
Today I did the rears, one side at a time. The passenger side went easily. The hardest part was lining up the hole for the bolt in the front.
The driver's side was easy up until the front bolt. The nut wouldn't budge so I called it a day and will try again tomorrow, most likely will use a cutoff wheel to cut the spring and remove that, then cut the bolt. I knew it was going tooooooo smoothly. Ugggggghhhhhh
drfister
May 3, 2018 10:38 PM
Urambo Tauro
Dec 17, 2016 03:30 PM
spectreman
Mar 31, 2016 09:26 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
robjh22
Aug 17, 2015 07:35 AM
