Electric water pump
Old Sep 28, 2009 | 09:37 AM
68stanger's Avatar
68stanger
Default Electric water pump
Having my engine rebuilt and considering an electric pump upgrade. I have a 68 289 that now has a 302 rods and crank. If I get an electric pump, is it easy to just get new belts to run the alternator and power steering pump or do I have to get some kind of kit and idler pulley? The engine is still in parts so cannot check out my block with those items installed.
Old Sep 28, 2009 | 12:11 PM
67mustang302's Avatar
67mustang302
It's a waste of money on 99% of street engines. Unless you're built to the hilt and searching for power in every last possible place there's no need. They do have their advantages, but a mechanical is fine in most applications. To answer your question though you can get the pumps with or without a built in pulley and either run the belt to just the alt and p/s pump(if it doesn't interfere with the water pump) or get a pump with a pulley and use that as a centrally located idler. If you do get one go with a Meziere.
jwog666
Dec 27, 2021 08:09 PM
jerrytubes
Oct 23, 2015 12:11 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
mrappe
Sep 26, 2015 10:16 AM
