Solenoid issue???
Old Jul 14, 2005 | 01:16 AM
earlymustang's Avatar
earlymustang
Default Solenoid issue???
I just replaced the generic solenoid in my 65 w/ a new FOMOCO reproduction model. The engine turns over just fine, but it does not want to start. When I finally got it started (after a ton of gas), it died after I let off the gas. Before it would start just fine.
Does installing a new solenoid alter the timing?
Would the engine turn over if it was installed incorrectly?
I labeled the wires and installed them as they were previously on the generic one.
Old Jul 14, 2005 | 01:36 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Solenoid issue???
The solenoid has nothing to do with the gas. It's purpose is to connect 12 volts from the starter switch to the starter. That's all. It sounds as if you have a fuel issue, and not an electrical issue.
Old Jul 14, 2005 | 08:42 AM
65_2plus2's Avatar
65_2plus2
Also check your timing. If you bumped the distributor, it can really screw with ya.
Cheers [sm=icon_guiness.gif]
Old Jul 14, 2005 | 11:55 AM
horseshoeing's Avatar
horseshoeing
What kind of fuel pump do you have?
Old Jul 14, 2005 | 02:20 PM
dodgestang's Avatar
dodgestang
You did make sure to reconnect the run and start wires to all the correct posts on the solenoid right? The first thing to do is to just reinstall you old solenoid and see if the problem goes away.
Old Jul 14, 2005 | 11:38 PM
earlymustang
I finally got it corrected. I had one of the wires hooked up to the wrong post. Pretty stupid I know. At least I had the sense to label each wire w/ masking tape just in case.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
