Does a carb spacer really help
Old 11-17-2009, 07:19 PM
MonsterBilly
MonsterBilly's Avatar
Default Does a carb spacer really help
i added a 1" to my set up. at the same time i also added octane booster. I am not sure which of the two made a diff but it was really noticable.
However, it ended up hitting my hood. so i removed it. I am going add a 351 scoop and cut out the hood so it will clear in the future, but does it really make a big diff?
MonsterBilly is offline
Old 11-17-2009, 08:20 PM
nba1341
nba1341's Avatar
It terms of what?
It did a huge difference for me in terms of heat dissapation so my fuel NEVER boils over in the summer. And you living in arizona would have this problem way more than californias 105 degree summer days. I can start my car on a 105 degree day without it dying.
As for performance wise I noticed maybe a little bit of difference in peddle responsiveness but it might have just been all in my hand
I had to trim my air cleaner riser and my air cleaner wingnut to make everything fit.
nba1341 is offline
Old 11-17-2009, 08:23 PM
2+2GT
2+2GT's Avatar
Oh yeah. Improves low-mid rpm throttle response. You don't think Ford was spending money on stuff that did nothing? They switched to Cougar reflectors in mid-68 to save a few pennies.
2+2GT is offline
Old 11-17-2009, 08:46 PM
Gun Jam
Moderator
Gun Jam's Avatar
which spacers are you guys running?
can you link me to your favorite one??
Thanks
-Gun
Gun Jam is offline
Old 11-18-2009, 06:31 AM
kalli
kalli's Avatar
phenolic 1" spacer worked wonders for me and friend of mine.
my problem was after car switch off fuel would vaporize, carb would get really hot and very hard to start. my buddies carb got so hot in idle just standing there that the car cut out.
I bought that one from summit. comes with studs (the right size) and bolts. I just bought 2 gaskets with it. the lower one i left completely open and the top one to match the 4 holes
http://www.summitracing.com/parts/EDL-8711/
(the two gaskets actually show op on right hand side).
kalli is offline
Old 11-18-2009, 07:09 AM
nba1341
nba1341's Avatar
I run the same exactly carb spacer he described and also experienced the same exact problem his buddy was having which is now fixed.
nba1341 is offline
Old 11-18-2009, 07:34 AM
Norm Peterson
Norm Peterson's Avatar
Spacers also add plenum volume and can affect mixture distribution. It is also possible for a spacer to increase the flow that the engine actually sees, since this depends on more than just the carb rating.
The best spacers are the tapered ones. Apparently they're good enough that some racing organizations have outlawed them for some classes (in circle track racing, I think, but don't hold me to it).
Very approximately, a tapered spacer goes from being a four hole spacer at the top (carb base) to an open or nearly open spacer at the bottom (manifold). There's more explanation at the bottom of this page. Like any other piece of advertising, I wouldn't place much importance on the numerical claim ("as much as 110 cfm" in this case), since you don't know the circumstances under which that was observed (and I highly doubt that their 110 cfm gain was measured with a 600-ish cfm carb on a 289/302 with OE heads).
Norm
Norm Peterson is offline
Old 11-18-2009, 08:54 AM
orange88
orange88's Avatar
Dumb question, 2+2 what is a cougar reflector?
orange88 is offline
Old 11-18-2009, 10:40 AM
Norm Peterson
A mirror in front of an older single woman?
Old 11-18-2009, 10:45 AM
Gun Jam
Moderator
Gun Jam's Avatar
-Norm
thanks for the info I wonder if I can find that in phenolic or is there a reason they are made from Al? I wonder If that one would fit a Carter AFB 600???
Thanks again guys!
-Gun
Gun Jam is offline
Quick Reply: Does a carb spacer really help
