Alternator Check
Old Nov 20, 2009 | 11:27 AM
WarrenW's Avatar
WarrenW
Question Alternator Check
Hi Everyone,
My battery must not being charged cuase after 3+ days it is dead. I can re-charge it and I'm good to go a few more days. This is in a 65 Mustang with 6 cyl 200. I looked at the alternator and it has the wires attached on with a nut rather than a plug. If I bring the alternator to an auto store, can they check one like this? And if the alternator is fine, what would be my next place to check on the car?
Thanks!
Warren
Old Nov 20, 2009 | 11:47 AM
2+2GT's Avatar
2+2GT
Do a full-field test on the charging system, if the voltage pegs out, the alt is OK and the regulator is bad.
There is no plug on the back of the alts in Mustangs, the plug is in the wiring between the alt and solenoid.
Any decent auto parts store can test an alternator, but with the full-field test you can check it in the car.
Old Nov 20, 2009 | 12:00 PM
67t5ponycoupe's Avatar
67t5ponycoupe
I'm not sure doing a full field test is a good idea for the novice. He might be better off just taking it to AutoZone.
Old Nov 20, 2009 | 01:06 PM
Stepman's Avatar
Stepman
I disagree. Just supply battery voltage to the field while monitoring voltage at the battery for A FEW SECONDS....if you see a major increase in batt volts, it's reg or wiring issue. Even a novice can do it.
Old Dec 1, 2009 | 08:51 AM
WarrenW's Avatar
WarrenW
Hi, can someone tell me the steps for doing a full field test on it? Although I do not know the procedure, I consider myself a little above a novice since I do most work on the car myself including electrical. I'm just still learning more as I go. I have not had a chance to get to the car with the holidays and all but need to have it going this week. Since my Avalanche transmission went out I get to go camping with my Mustang with the Cub Scouts! Atleast its local...
Warren
Old Dec 1, 2009 | 09:03 AM
WarrenW's Avatar
WarrenW
I just read in another forum that if a wire is loose or problems in your instrument cluster that it will cause the alternator not to charge. I have not changed anything on mine but possible something could have come loose. Just a thought. A replacement alternator is only $29 at Advance Auto Parts so I may just pick one up today anyways. I put a new voltage regulator in earlier this year after it fried my battery!
Golfsito
Oct 6, 2015 11:02 AM
Wombatnation
Sep 13, 2015 09:16 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
Mobiusone stang
Sep 7, 2015 08:46 PM
