Gasket kit
Old Dec 12, 2009 | 05:25 PM
indystang66's Avatar
indystang66
Default Gasket kit
The gasket kit for the 289 is the same for the hi-pos right?
If there is any different what would they be? Water pump?
Also, what is a decent kit? Is the Fel Pro overhaul kit for $60 a good choice. Includes
Set includes the following gaskets:
Cylinder head - Part # 8548PT2
Distributor
Exhaust manifold
Fuel pump
Intake Manifold
Oil pan - Cork
Oil Pump
Rear main seal
Timing cover gasket & seal
Valve stem seals
Valve cover - Cork
Water pump
Water
Old Dec 14, 2009 | 08:25 PM
indystang66
Any opinions?
Old Dec 14, 2009 | 11:44 PM
hiboostwoody's Avatar
hiboostwoody
Fel-Pro gaskets are good stuff but get a set of rubber valve cover and oil pan gaskets instead of that cork crap.
Old Dec 15, 2009 | 02:18 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
yeah a 1 piece oil pan gasket is a must
Old Dec 15, 2009 | 05:47 AM
2+2GT's Avatar
2+2GT
Depends- I use good quality cork gaskets on my 289HP. Rubber gaskets just won't seal properly on 45 year old steel valve covers, so I glue a set of cork gaskets to the covers with Permatex. The current set has been off and on at least 4 times, still no leaks, which is typical. Normally, they last until it get careless and damage one.
Old Dec 15, 2009 | 07:24 PM
indystang66
Ok thanks for the input!
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
Drastang
Sep 30, 2015 03:48 AM
wraith777
Sep 28, 2015 10:49 AM
