help converting 64.5 brakes--switch
Old Dec 15, 2009 | 09:09 PM
ArmyDave's Avatar
ArmyDave
Default help converting 64.5 brakes--switch
64.5 drum brakes, single master cylinder.. Got the dual master cyl from cj pony parts. bought a brake switch for a 65-66. Dont know how it goes on. If its supposed to fit on the same pin as the master cyl rod on the brake pedal, it doesnt. It sticks out. Can someone take a pic of theres maybe or Really explain it to me.
Old Dec 15, 2009 | 10:10 PM
2+2GT's Avatar
2+2GT
You can't use the 65-up mechanical switch on the 64 pushrod. That requires a flat spot on the rear of the rod, and different bushings.
Old Dec 16, 2009 | 06:10 PM
ArmyDave's Avatar
ArmyDave
You are a genius, i figured that out today. I also found out my pedal is the wrong one also. I need to have a longer pin that holds the switch and rod. Great--- more money.
Old Dec 17, 2009 | 11:17 AM
kalli's Avatar
kalli
the brake switch in my 64 was a hydraulic one tyhat bolted directly into the single master.
I upgraded to dual master cylinder and just plumbed the original hydraulic brake switch into the hydraulic system with a T-piece. I couldn't locate such a piece over here. If you can't find them anywhere, Denis from discbrakeswap is aware of this (i got all my brake gear there). He can sort you out.
I'll see if I can take a picture
best regards,
Kalli
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
jerrytubes
Oct 23, 2015 12:11 PM
guitarman376
Sep 30, 2015 05:54 PM
