Getting 429
Old Dec 23, 2009 | 08:27 PM
  #21
LynnBob Mustang's Avatar
LynnBob Mustang
Originally Posted by urban_cowboy
Regardless, I honestly have not seen a 429 without hemi style heads in a classic mustang. Surprising that it will fit.
You must have never seen or heard of a '71 429 SCJ car then?
http://www.google.com/imgres?imgurl=...ed=0CA0Q9QEwAw
Lynn
Old Dec 23, 2009 | 08:33 PM
  #22
LynnBob Mustang
I had a built C6 backed with 4:30 gears with my 429 in my '71 coupe and I could broil the tires off in drive doing 30 MPH, forget about 1st...... She was all kinds of side ways.
I miss that car.
Lynn
Old Dec 23, 2009 | 08:40 PM
  #23
LynnBob Mustang
Originally Posted by 2+2GT
Some work will be required to attach a shifter to the trans.
I had a stock shifter in mine with a C6, I don't think anything special was done with the linkage.
Although some of my parts my have come from a SCJ car as they did come with auto's as well.
It has been 25 years since I had the car and remember how I got it.
Lynn
Old Dec 23, 2009 | 08:49 PM
  #24
NuclearMuscle523's Avatar
NuclearMuscle523
SCAM ALERT! This person is known around the internet for ripping people off. You've been warned.
What about any other manual? Like a T5. I don't really want auto.
Old Dec 24, 2009 | 07:17 AM
  #25
67 evil eleanor's Avatar
67 evil eleanor
I would consider the use of the car. If you are going to be on the highway a lot, then the work to install a TKO with either a .64 or .68 overdrive would be very much worth the trouble, provided its matched with the right rear. I have a 71 "J" code that I will be starting in the near future and so far finding a Toploader has been difficult (without a second mortgage). Actually the more I think about it, the better the TKO sounds. They are several big spline "Torino" trannys out but don't be fooled, the tail shaft is too long for the Mustang and more than likely your gonna hear "yep, they will fit". The ones native to the Mustang should have RUG AZ ot RUG AZ1 on their tag and have the short tail shaft, oh yeh, expect to pay a couple grand for the right tranny. A good ole C6 should be a straight foward install and they have a tough gut. Put a T5 (unless its build to the hilt) and you will see just how quick a tranny can disintegrate. On the 429's fitting, I have seen a 429 in a 65. It was a VERY tight squeeze and I think the towers were altered, but it was in there. One of the biggest considerations you also need to weigh in literally is just that, the weight. These are the heavyweights and its gonna feel like the nose is going to pull you out of the curve. If you do like a straight liner, then your in business.
Old Dec 25, 2009 | 08:33 AM
  #26
2+2GT's Avatar
2+2GT
I know how you feel. As much as I respect the T5 for use in SB Ford conversions, I think with the massive torque of the 460 you'd be trailing transmission parts by the time you got to the end of the block on the first test drive.
Old Dec 25, 2009 | 03:40 PM
  #27
NuclearMuscle523
So what should I do with the engine since I don't know how many miles are on it and if it runs? Nice intake? nice user-friendly carb? Hi-comp pistons? freeze plugs and gaskets?
Old Dec 25, 2009 | 04:14 PM
  #28
67 evil eleanor
I would put a pencil to what you have. On the 429, yep you can make it work, but at what cost. A 429 is a beast, sure, in common form it will shread the tires off any vintage Mustang you put it in. On the flip you will know its up there the first curve you dive into. In order to lighten the load, at the least you will need aluminum heads and intake to even get clost to a good handleing car. In my opinion the 351w with aluminum intake and heads offers one of the best F/R ratios. What will a well built "Winsor" set you back vs the 429? This is the time to pull out the pencil. On the tranny end, I think you are looking at a couple thousand at a minium for either a Toploader or TKO considering the associated cost of the clutch, flywheel, PP, TB, scatter shield (don't cut yourself short), clutch cable etc and so on. Take your time, hasty decisions are most often not the right ones.
Old Dec 25, 2009 | 06:58 PM
  #29
NuclearMuscle523
I am getting motor and trans for $350
Old Dec 26, 2009 | 12:17 AM
  #30
Silverblade's Avatar
Silverblade
what is your goal for the car and what is your goal for hp/tq?
is it a drag car? if so build up the 429.
if its a cruiser, a 351W should give you the hp numbers you are after and will be way easier to put in.
