Replace this tire or not?
Old Dec 28, 2009 | 04:38 AM
  #31
tx65coupe's Avatar
tx65coupe
Originally Posted by 4reboy
Well regarding putting the old tires on the front, that probably won't happen for me only because I have bigger tires in the rear... I don't want to try and turn 245's up front with my manual steering, the 235's are hard enough.
Also, I haven't bought new tires yet, I have gone the used tire route. I can get a tire with 70% or more tread left, mounted and balanced for 20-30 bucks depending on the tire. I'm going to try to earn some money around the house or something to at least get 4 GOOD used tires, maybe 225/60/14 in front and 245(or255)/60/14 in the rear. It all depends on what the shops have on hand... I've also considered going to 65 in the sidewall height, the 60% sidewall on a 14" tire seems small, but maybe it's because my car is like a monster truck right now.
I may look into new tires if I can find them for a good price. I just now I need to replace the fronts because of serious dry rotting, I believe the rears are only cracked on the top of the sidewall, but not in between the treads so they should be okay for awhile. I'll give it a better inspection when It's back on all 4 wheels
The problem with used tires is that even though they may look good, they could be several years old. That makes them more prone to being hard and dry rotting. I won't ever buy used tires.
Old Dec 28, 2009 | 04:40 AM
  #32
tx65coupe's Avatar
tx65coupe
^now I really want new tires. I don't want to have a blowout.
The past 6 months or so I've just dropped the tire pressure down a bit to reduce failure chances. I'll start lookin for some other tires...
Couldn't dropping the pressure actually make the tires run hotter and increase the chances of failure? I would just leave them at about 32 like they are supposed to be. What are you running them at anyway?
Old Dec 28, 2009 | 01:49 PM
  #33
4reboy's Avatar
4reboy
around 31-33. When I said drop the pressure I didn't drop them a considerable amount, just a little to make the tires less hard so to speak. This was just the advice of the tire guy. Before I was running around 34-36 psi
Old Dec 28, 2009 | 01:53 PM
  #34
TheMarco's Avatar
TheMarco
Gah... apparently it's hard to get white lettered BF Goodrich tires around here. I'm still looking Didn't want to ruin the look of my car by putting black ones on.
Old Dec 28, 2009 | 09:54 PM
  #35
Adrenolin's Avatar
Adrenolin
It seems to me that especially on a front wheel drive car having better tires on the front would be more important since the front wheels do the steering, most of the braking, and are the drive wheels.
Tire Rack also explains it well here when they got to test drive new tires on the front and the rear at Michelin's Laurens Proving Grounds. The top half explains it well and the bottom half tells about their experience.
Check out this link (Michelin) and read the last question regarding where to install two new tires. That link also includes a 2.5min video Mounting Two Tires.
Just put newer tires with better grip on the rear wheels.
Old Dec 28, 2009 | 10:05 PM
  #36
Adrenolin's Avatar
Adrenolin
Can always order them through Tire Rack. Raised white letter Radial T/As. I have a local National Tire & Battery (NTB) mount them on the wheels and balance for me. You can either order directly through TR and have shipped to a local shop or price match from a local shop like NTB. If your local shops cant get the white letters just order them direct.
Old Dec 29, 2009 | 01:22 AM
  #37
TheMarco's Avatar
TheMarco
After calling about 20 shops I found one little local place that will have them and install them wednesday or thursday
Old Dec 29, 2009 | 05:29 AM
  #38
tx65coupe's Avatar
tx65coupe
Thats odd. Around here they are easy to get. Have you checked Discount Tire or NTB?
EDIT: I just saw that you found a place.
Old Dec 29, 2009 | 05:30 AM
  #39
tx65coupe's Avatar
tx65coupe
I always run mine at 32 anyway. Thats what the tire shop sets them at as well. I think max on mine is 35.
Old Dec 29, 2009 | 05:34 AM
  #40
tx65coupe's Avatar
tx65coupe
Thats interesting. I guess it makes sense. I just would have thought differently.
Granatelli Sales
Jan 20, 2020 12:34 AM
musnicki
Sep 23, 2015 07:11 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
ccwebb
Aug 11, 2015 06:47 PM
