greasing ball joints
Old Dec 27, 2009 | 11:43 PM
67 newb's Avatar
67 newb
Default greasing ball joints
Hey guys,
I borrowed my friend's grease gun and was going through all the zerc fittings. I was able to do about 3 pumps into the lower control ball joint, when the grease started coming out of the bottom edge. However, the ball joint was still soft as if it's empty inside. Should I continue to pump it even though some amount is coming out through the edges? Or is it full and ok?
Thanks
Old Dec 28, 2009 | 04:51 AM
tx65coupe's Avatar
tx65coupe
If its coming out of the edges then adding more won't really do any good. You may need to bounce up and down on the front of the car some and then try to add more grease. You'll need to put the tires back on to try that. Sometimes that will allow more grease to go in.
Did your lower control arm come fully assembled? If it did, it may have already been greased. I know my upper A arms came like that. I can't remember if the lowering ones did or not.
Old Dec 28, 2009 | 06:59 AM
2+2GT's Avatar
2+2GT
Many ball joints come with a relief in the boot edge to prevent "popping" the boot like a balloon.
Old Dec 28, 2009 | 12:36 PM
67 newb's Avatar
67 newb
The LCA was already assembled when I purchased it. I'll make note to check it once the tire is in, and to double check all the joints again after driving...
Old Dec 28, 2009 | 01:53 PM
4reboy's Avatar
4reboy
I was disappointed that my LCA ball joint is a sealed unit, no spot for a zerk fitting. I don't know if this will be good or bad haha
6bangr
Feb 15, 2016 07:40 AM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
guitarman376
Oct 11, 2015 01:47 AM
marc954
Sep 29, 2015 11:18 AM
gagemcc
Sep 22, 2015 09:43 AM
