69 speedometer cable
Old Jan 2, 2010 | 09:48 PM
relic1864's Avatar
relic1864
Default 69 speedometer cable
Does the speedometer cable on a 69 coupe just unscrew from the back of the instrument cluster or is it held on by nuts?
Old Jan 2, 2010 | 09:52 PM
forsho1's Avatar
forsho1
Mine just unscrews from the back of the cluster.
Old Jan 2, 2010 | 09:58 PM
relic1864's Avatar
relic1864
Default cable
have you ever replaced the instrument circuit board on your 69?
Old Jan 2, 2010 | 10:26 PM
67t5ponycoupe's Avatar
67t5ponycoupe
I'm pretty sure 69 is the first year of the push on end at the speedo head. So no nuts or anything like that.
Old Jan 3, 2010 | 11:13 AM
hotrod351's Avatar
hotrod351
i have a 70 and theres a plastic clip at the end. you have to pry it up with your fingers and it will pull off. as for getting a new one i had to have a place make one, $60.00 with the proper ends. checker sells them but there about a foot to long.
Old Jan 3, 2010 | 12:47 PM
2+2GT's Avatar
2+2GT
parts store cables are often too long, to fit many applications- sort-of. Get a proper length cable from a good Mustang supplier.
You don't pull on the clip ring, you push on the big tab on the right side of this picture:
Old Jan 3, 2010 | 01:08 PM
4reboy's Avatar
4reboy
My 69 doesn't even have a clip like that, just pull off, push on. However it's a pain in the ***, Have to use a wrench, screwdriver, whatever to get leverage on the small edge. Maybe if all the parts were new it would be better, when I got my car the cable end was bent to crap
Old Jan 3, 2010 | 01:10 PM
oldrock's Avatar
oldrock
I just did the cable on my 69 coupe a couple months ago and it had the plastic retainer like in the picture. Also they are right on the money about the length. I got what was suppost to be the correct cable at oreileys and it ended up being about a foot too long. I made it work by ziptieing the extra cable under the car but I'd get the right one from a mustang shop if I was you.
Old Jan 3, 2010 | 07:30 PM
Stepman's Avatar
Stepman
This should be the correct way.
articman
Jun 21, 2018 11:45 PM
Thunderball
15
Nov 22, 2015 11:49 PM
kevsgt
Oct 9, 2015 10:12 PM
breaking
Oct 2, 2015 01:27 PM
Explosive
Oct 2, 2015 07:45 AM
