65 Basic Question
Old Jul 24, 2005 | 01:44 PM
djustham's Avatar
djustham
Default 65 Basic Question
Hate to ask this basic question but.... Just bought a 1965 with a 289 and automatic transmission. On the shifter plate for Drive you have a white dot which is the first one then a green dot and then L. Which one do you normally drive in the white dot or the green dot? Sounds stupid, but I don't know. Thanks
Old Jul 24, 2005 | 02:40 PM
skiprCH's Avatar
skiprCH
Default RE: 65 Basic Question
Hi,
Welcome to the forums! I have the same setup and drive in the green dot. The white dot is second gear. If you drive in the white dot you will start out in second and up shift once. If you drive in the green dot you will start out in low and up shift twice. The green dot will get you off the line quicker. By the way do you have a console in you stang? I am putting in a console and have some questions.
Walt
Old Jul 24, 2005 | 05:13 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: skiprCH
Hi,
Walt
What questions do you have about the console installation, Walt? I put mine in a few summers ago. Even though mine is standard tranny, the only difference is the shifter plate. Also, specify if you have air conditioning. The long console is a tad more complicated.
Old Jul 24, 2005 | 09:09 PM
skiprCH's Avatar
skiprCH
Hi Soaring,
The problem I have has to do with the shift slide and gear indicator for the A/T. I got the console fitted in ok. I just have a gap between the console shifter plate and the shifter slide and gear indicator. I have about 1/4 in. between the two. Does not look right. I have added some washers to take out some of it. I was trying to get someone with a '65 A/T to tell me what it supposed to look like. I should have looked harder at some of the cars at the stang rally a few months ago.
Thanks, Walt
Old Jul 26, 2005 | 09:52 AM
6mustang6's Avatar
6mustang6
is it maybe a convertible console? I know there are two different kinds of console, one for coupes and one for convertibles. Maybe you got the wrong one
Tivo304
Aug 28, 2023 12:19 PM
Ipaman
Sep 22, 2015 07:01 AM
04stangman
Sep 17, 2015 01:45 PM
