disc brake question
ok i currently have power drums, which i converted to power without changing the brake pedal (added aftermarket booster). I want to upgrade to disc in the front, however ive been reading that you have to have a different pedal when it comes to disc power. Im wondering if this is true and should i just go manual disc. This isnt my daily driver so i can put the extra leg into it if need be. If i kept the pedal the way it is and ran power disc what will happen? Its for a 68 mustang. thanks guys
Power drum and power disc used the same pedal. The pedal change was due to the difference in leverage for the factory booster, to prevent excess sensitivity. If your booster/pedal setup is working OK, leave it alone. Make sure you check the headspace on the disc master cylinder when you install it.
Someone added a booster to my car before I bought it but did not change the brake out. Overly sensitive and would lock up easy. Just recently started disk swap. Changing out MC, pedal (not that big of a deal), and putting porportioning valve in. See CSRP they have a good price on pedals - I've also seen them at mustang unlimited.
Holly-Molly, you talk about a "Grouping" of Disinformation, this takes the cake.
The 65 66 Pedal are the same. Disc Pedal Vs Drum pedal amounts to pad Size.
There are 4 Different pedals for the 67-70 Mustangs.
67 Small Pad with stop
67 Big pad with stop
68-69 Big Pad, No Stop
70 Pedal
Again, Standard Pedals, vs Auto Pedal have to be intered into to the equasion.
Dan @
Chockostang
70 Pedal
Dan @
Chockostang
Manual brakes when set up correctly shouldn't require a bunch of leg effort. When done properly they should operate with about the same effort as a power system that uses a firmer pedal, and with very good feel and modulation characteristics.
Good site on brake pedal differences. Hope it helps clear things up.
http://www.mustangsteve.com/fyi_brak...akepedals.html
musnicki
Sep 23, 2015 07:11 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
