small air cleaner?
Old Jul 26, 2005 | 07:32 AM
panteramatt's Avatar
panteramatt
Default small air cleaner?
I need a air cleaner thats pretty small in size cause when I close my hood, I notice there isnt much room at all. I want one that will work with the scoop to get more air. I remember seeing a small triangle one with a mesh top but dont know where to get it?
Old Jul 26, 2005 | 09:38 AM
68COOP's Avatar
68COOP
Default RE: small air cleaner?
Auto Zone is where I got mine, but I wouldn't recommend it. Get a K&N if at all possible.
Old Jul 26, 2005 | 09:40 AM
lClutchl's Avatar
lClutchl
Summit Racing: 23.95 + shipping
http://store.summitracing.com/defaul...=egnsearch.asp
Old Jul 26, 2005 | 01:36 PM
Markstang1969's Avatar
Markstang1969
This kind is an edelbrock on mine, but I will change out for a K&N when I can.
Old Jul 26, 2005 | 04:52 PM
panteramatt
What k@n's can I use cause there really isnt much room under there and I want to utilize the ram air effect.
Old Jul 26, 2005 | 05:03 PM
69mach1377's Avatar
69mach1377
Use a drop base type for more hood clearance.
A cotton type will flow more air for a given size.
Old Jul 26, 2005 | 09:48 PM
panteramatt
Id like a k@n type if filter and one that can flow through the top and still looks pretty nice, any thoughts?
Old Jul 27, 2005 | 12:13 AM
68COOP's Avatar
68COOP
Matt, go to their site, they have filters that are shaped exactly like the whole set-up. The WHOLE thing is a filter, housing is shaped identical to the factory kit, but it's ALL filter! Did I say it was probably the best thing you will find that really works, and still toerate to look at it.
Old Jul 27, 2005 | 01:05 PM
69mach1377's Avatar
69mach1377
Be careful, I tried a drop base with a filter top and it must have messed up the flow into the carb real bad. It ran poorly under throttle but cleared up when I replaced the top with the regular one. The filter top probably needs to be at least 3 inches above the top of the carb...
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
daltron
Apr 28, 2016 08:10 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
UrS4
Sep 30, 2015 10:13 AM
