Faded Carpet Options?
Old Feb 24, 2010 | 08:34 PM
nba1341's Avatar
nba1341
To remove the seats drive up a curb remove one seat then switch sides and drive up the curb again.
that way you don't need to jack up the car at all at only 1 tire of the car is not level to the ground
dying carpet wont last long enough i mean for 5 bucks its cool but it gets annoying after less than 2 years and your carpet is fading again.
Old Feb 24, 2010 | 09:17 PM
andrewmp6's Avatar
andrewmp6
To dye it right you need to remove the carpet to get it all one color.Its a lot easier to just replace it.
Old Feb 25, 2010 | 04:23 AM
tx65coupe's Avatar
tx65coupe
Here is another vote for new carpet. Its really a rather easy project.
Old Feb 25, 2010 | 04:30 AM
nba1341's Avatar
nba1341
Yea and its not that hard to fit back in. I had to remove my seats and refit the carpet like 3 times in a week (insulation install, redye carpet, stereo wiring) and it was definitely one of the least stressful things i have done with the car
Old Feb 25, 2010 | 10:50 AM
1971mach1's Avatar
1971mach1
I've done it on several cars in the past. It's mostly time consuming
for the amateur, taking off all the pieces. With a console it's harder. It gets tricky and the fumes are stinky if you want it glued down for the professional look. With that 3M contact adhesive spray, it sure looks good. That was when I had more time than money, now it's the reverse, so I bought the carpet on-line and paid a pro to do it right (I think labor was around $200).
I've also done the carpet dye, JC Whitney has it. It works fine for small areas but forget it for the
big jobs. Might as well just replace the carpet. It stiffens the carpet too.
jwog666
Dec 27, 2021 08:09 PM
StalkerGT
Nov 28, 2015 03:09 PM
b8checker
Oct 8, 2015 12:55 PM
ChampInSD
Oct 2, 2015 04:55 AM
b8checker
Sep 30, 2015 07:11 AM
