carb question
Old Mar 3, 2010 | 09:21 AM
waldo786's Avatar
waldo786
Default carb question
Is there any difference in the I6 200 1 barrel carb from 65-67? If what I've seen is right they seem to be the same. Thanks!
Old Mar 3, 2010 | 12:13 PM
67t5ponycoupe's Avatar
67t5ponycoupe
I believe they are all the same. If you are looking for a good upgrade the I6 Granadas had a Holey one barrel that works quite nicley on the Mustang.
Old Mar 3, 2010 | 12:18 PM
1slow67's Avatar
1slow67
ROTM Moderator
Yes they are the same. I went through 2 1bbl carbs before I upgraded to my 2bbl setup I have right now. Those 1bbls couldn't take it
Old Mar 3, 2010 | 01:17 PM
2+2GT's Avatar
2+2GT
Essentially they were the same, except of course the manual trans cars had a different carb than the auto trans.
Manual:
Auto:
Old Mar 3, 2010 | 01:29 PM
1slow67's Avatar
1slow67
ROTM Moderator
Wasn't it just the extra accelerator pump?
Old Mar 3, 2010 | 02:24 PM
2+2GT's Avatar
2+2GT
No, the accelerator pump is on the other side, on both. That's a dashpot, which reduces rapid movement of the throttle, to prevent stalling at stops and improve fuel econonmy when moving.
Old Mar 3, 2010 | 03:56 PM
67t5ponycoupe
I learned something, thanks.
Old Mar 3, 2010 | 04:21 PM
waldo786's Avatar
waldo786
Thanks for the replies guys that info was very helpful. Interesting tip about the Holley carburetors.
Old Mar 3, 2010 | 04:28 PM
67t5ponycoupe
I have found a lot of the Autolites are worn out where the butterfly shaft goes through the body of the carb and they leak vaccum.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
UrS4
Sep 30, 2015 10:13 AM
treesloth
Sep 28, 2015 07:03 AM
