Brake line stuck
Old Mar 14, 2010 | 10:27 AM
  #21
xswoopr's Avatar
xswoopr
I agree with 2+2 GT, take his advice and toss those air shocks, they could cause immense problems.
Old Mar 14, 2010 | 11:14 AM
  #22
2+2GT's Avatar
2+2GT
Originally Posted by 67 newb
For the shocks, I pulled out the rubber plugs in the trunk and unbolted it from the top. Shocks fell right down. As for the brake line, the flare nut wrench stripped the bolt as well, so I basically used 2 vice grips and was able to get the job done.
I'm still unclear why you were disturbing the brake hose. Were you replacing it?
The flare nut is the captive nut at the end of the steel line. When these are distorted, it can be very difficult to get a proper seal when tightening them. The only way to replace them is to cut and re-flare the end of the line. Even if you are careful, this shortens the line 1/2-1". If the line is rough with oxidation, the job gets harder. As noted, this makes the line too short.
The shock crossmember is not built to bear weight. The crossmember in this Shelby was destroyed by air shocks, and had to be replaced.
Old Mar 15, 2010 | 01:14 AM
  #23
67 newb's Avatar
67 newb
yup, replacing all lines. Pulled out the axle and wire brushed off about 1/4" worth of dirt and mud build up. Next is the wheel wells
Oct 7, 2015 07:02 PM
67LimeCoupe
Sep 21, 2015 06:34 PM
Sep 16, 2015 07:53 PM
DoctorScary
Sep 9, 2015 07:53 AM
Sep 8, 2015 11:50 AM
