stuck
Old Mar 10, 2010 | 09:37 PM
1967coupeon101's Avatar
1967coupeon101
Default stuck
Can't separate the outer tie rods from the lower end of the spindle. Same with the idler arm from the rest of the steering linkage. how can I pop those suckers out? I've tried everything???
Old Mar 10, 2010 | 09:48 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Take the nut off and smack it really hard with a BFH on the knuckle. You can also back up the knuckle with another BFH, that will help. The other way is with a pickle fork.
Old Mar 10, 2010 | 09:54 PM
1967coupeon101
figured brut force with a blunt object was necessary
Old Mar 10, 2010 | 10:12 PM
a_penquin's Avatar
a_penquin
Pickle fork and a 5lb hand sludge, you can also use an air hammer with a pickle fork attachment. If those fail you may have to bust out the torches to heat the knuckle. I have to get the heat out sometime for my balljoints
Old Mar 10, 2010 | 10:16 PM
retro77's Avatar
retro77
Pickle fork! About $11 at most auto parts stores.
Old Mar 10, 2010 | 10:30 PM
1slow67's Avatar
1slow67
ROTM Moderator
Most places don't recommend using a pickle fork because it does mess up your ball joints.
Old Mar 11, 2010 | 12:00 AM
1967coupeon101
dont plan on re-using the ball joints have all new suspension including ball joints so ill give the pickle fork a shot if trying to knock it out doesnt work.
Old Mar 11, 2010 | 01:15 AM
67t5ponycoupe
Hit the knuckle on the side with a big freaking hammer with a big freaking hammer on the other side of the knuckle. It will work. I have pickle forks and still use that method because it won't mess up the grease boot.
mrtrodonet
Sep 19, 2020 03:12 PM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
jstrothe
Sep 24, 2015 12:17 PM
rafotree
Sep 22, 2015 03:55 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
