351c oil leak
Old Apr 18, 2010 | 03:27 PM
Arnold_se91's Avatar
Arnold_se91
Default 351c oil leak
My 351c is leaking alot of oil from rear of the intake manifold. The thing I'm wondering is does the intake manifold have oil flow through it or is an underlying problem of something else? If you've had this problem before I'd love some advise!
You can email me at Arnold_se@yahoo.com
thanks
Old Apr 18, 2010 | 03:33 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
remove intake reseal bamm fixed....also check the oil fitting there for the guage
Old Apr 18, 2010 | 03:39 PM
Arnold_se91
I already changed the sensor. That wasn't it. So it must be the intake manifold seal
Old Apr 18, 2010 | 03:40 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
yep probably...just remove it and reseal it
Old Apr 19, 2010 | 05:17 AM
kalli's Avatar
kalli
clean it all up properly and then recheck when it's tidy. leave run for a while so you know exactly where it's coming out. would be a PITA to replace perfectly good intake gaskets (whichg can go horribly wrong if never done before) and all you needed was a bit of teflon tape at the oilpickup thread.
make sure where it's coming from first, which will be easy if perfectly clean
mustangheaven
Jan 3, 2016 11:20 AM
jerrytubes
Oct 23, 2015 12:11 PM
mustangheaven
Oct 7, 2015 10:23 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
mustangheaven
Sep 29, 2015 11:00 AM
