It Happened!
Old May 5, 2011 | 02:59 PM
  #271
1slow67's Avatar
1slow67
ROTM Moderator
Well went and bought a new Edelbrock 1406 and this is what I get on the first crank.
Old May 5, 2011 | 10:04 PM
  #272
1slow67's Avatar
1slow67
ROTM Moderator
Pics of the headers.
Engine
Old May 5, 2011 | 10:24 PM
  #273
hightower2011's Avatar
hightower2011
Wow, your engine looks incredible!
Old May 6, 2011 | 01:09 PM
  #274
1slow67's Avatar
1slow67
ROTM Moderator
Well nothing like having your oil look like coffee w/creamer.
Old May 6, 2011 | 01:47 PM
  #275
Jonk67's Avatar
Jonk67
Head gasket leak? or intake manifold leak most likely.
You have water getting into the oil through a gasket on one of those hopefully as gaskets can be changed.
Did you retorque the heads and intake following shop manual sequence after break in? Might not help now that the water has made a passage across a gasket but will be necessary if you change the gaskets to fix.
Jon
Old May 6, 2011 | 04:16 PM
  #276
1slow67's Avatar
1slow67
ROTM Moderator
It was the intake gaskets. I've got an extra set that I will use.
Old May 6, 2011 | 08:36 PM
  #277
Jonk67's Avatar
Jonk67
Will you make the Huntsville show tomorrow?
I think I've convinced the wife to let me go and take her '09 to show.
Jon
Old May 6, 2011 | 09:07 PM
  #278
1slow67's Avatar
1slow67
ROTM Moderator
Apparently because it would have no hood, I"m not allowed to take it to the show. It wouldn't be complete if I did either, I don't a lot of stuff put on the car. O well another ruined day I had planned. No car show and I work 8 hours.
Old May 9, 2011 | 01:41 AM
  #279
tx65coupe's Avatar
tx65coupe
Thats awesome that its running. Sorry, you missed the show.
I missed a show on Saturday too. The driveway was being worked on, so I couldn't get the 65 out of the garage.
Old May 9, 2011 | 01:55 PM
  #280
Jonk67's Avatar
Jonk67
Sorry you missed the show, lot of nice cars to look at. These shows are getting really new car top heavy though, only found a few coupes to look at.
I noticed charging cables in the last pic. You need to disconnect the battery cables when charging as the current can travel down the wires and ruin you alt./VR.
Jon
