It Happened!
Old May 4, 2011 | 05:19 AM
  #261
tx65coupe's Avatar
tx65coupe
I've had my share of stuff not fitting quite right too.
Old May 4, 2011 | 06:32 PM
  #262
nba1341's Avatar
nba1341
This has come along way very nice stuff!
Old May 4, 2011 | 09:32 PM
  #263
1slow67's Avatar
1slow67
ROTM Moderator
Going to start it tomorrow! All I need to do now is finish up my wiring and put oil in it.
Old May 4, 2011 | 09:34 PM
  #264
hightower2011's Avatar
hightower2011
Big moment is here! Looking forward to seeing how it turns out!
Old May 4, 2011 | 09:39 PM
  #265
1slow67's Avatar
1slow67
ROTM Moderator
Yeah today I took apart the carb to see what I could find out about it. Found 1 clogged jet and a lot of gunk in there. My dad had a problem with it idling under 2000 RPM and I think that might have been part of the problem. Will find out tomorrow, if it doesn't work I will be taking the carb off his truck. Also made a bracket and mounted my fuel pump.
Old May 5, 2011 | 12:11 PM
  #266
1slow67's Avatar
1slow67
ROTM Moderator
Cranked it! Going to try and get it running in the next half hour or so.
Old May 5, 2011 | 12:13 PM
  #267
hightower2011
Oh snap!
Good luck!
Old May 5, 2011 | 12:37 PM
  #268
1slow67's Avatar
1slow67
ROTM Moderator
And we have a problem. Its putting a major load on the ground wire of the alternator.
Old May 5, 2011 | 01:34 PM
  #269
Gun Jam's Avatar
Gun Jam
There should be an equal load on the + wire as well
Old May 5, 2011 | 01:40 PM
  #270
1slow67's Avatar
1slow67
ROTM Moderator
Well it was enough to put out smoke. I think it was just a bad ground.
