Resto-mod project
Old Mar 1, 2011 | 11:54 PM
  #231
hightower2011's Avatar
hightower2011
Originally Posted by Novice-Owner-Marc
Alright I gotta say, nice work dude!!
OK, so how and why does the rear end need to modify the rear end? Is it too wide? Does it need to be modified because the 4X4 gears?
I would like to see some pictures of the rear window. You definitely have gotten back in gear Chip. Good work!!
Since it's a 4x4 rear end the "pumpkin" is offset so that in a 4x4 explorer, it will line up with the transfer case, which is also offset. (I believe that's the reason, I could be slightly wrong)
For example, from one side of the "pumpkin" to the end of the axle is 52" on one side, and 55" on the other.
The mod is to simply cut it and weld it back in place a few inches shorter. User "MonsterBilly" started a thread and has already modified a few like I plan to do, I'm hoping he will at least write up a basic guide to help.
Thanks for the kind words Marc! I'll get some pics tomorrow if I get a chance!
Originally Posted by NoReins
Good job on the cowl. Now make sure you get the surface rust off with a wire wheel and spray a weld thru primer before you weld the cowl back on.
Thanks! What primer should I use and where should I get it?
Old Mar 2, 2011 | 09:42 AM
  #232
scootchu's Avatar
scootchu
Did you pick up a short side axle for the rear yet??
Old Mar 2, 2011 | 11:10 AM
  #233
hightower2011
I believe I need the passenger side axle to make them the same, I shouldn't have a problem finding one. I have however read of one user on here leaving the axle offset. I'm PMing him now to see what he did.
Old Mar 2, 2011 | 02:08 PM
  #234
jp1967stang's Avatar
jp1967stang
for the $150 about it is to have a shop to cut straighten and weld on leaf plates, i would not leave it offset.
Old Mar 2, 2011 | 05:17 PM
  #235
NoReins's Avatar
NoReins
For the weld thru primer, any brand is ok - we used U-Pol.
Old Mar 2, 2011 | 07:17 PM
  #236
hightower2011
You think a shop would cut the sides to match, weld them back up, and put on leaf plates all for $150? Heck, that's more worthwhile for me cause I really don't want to mess up the axle I'll be thrashing on...
Thanks, I'll pick some up soon!
Old Mar 2, 2011 | 07:39 PM
  #237
jp1967stang
At tin man fab which is up where i live. If i bring them the axle tore down with no guts in it and remove the existing explorer brackets on the tubes. They will straighten, shorten the one side and weld the leaf plates on. A shop told me most axles are bent a bit and need the straighing. Yes you could do it yourself but when I think about it 150 or so for a peace of mind knowing it was done by a shop that knows what their doing is worth it to me.
Old Mar 2, 2011 | 07:47 PM
  #238
hightower2011
At tin man fab which is up where i live. If i bring them the axle tore down with no guts in it and remove the existing explorer brackets on the tubes. They will straighten, shorten the one side and weld the leaf plates on. A shop told me most axles are bent a bit and need the straightening. Yes you could do it yourself but when I think about it 150 or so for a peace of mind knowing it was done by a shop that knows what their doing is worth it to me.
I totally agree, I just didn't know I could get it done for that price. It makes sense though if you bring it in gutted. All they have to do is cut and reweld it.
And it's definitely worth that peace of mind!
I'm actually going to my local shop in the next few days to ask what machine shop they would recommend I take my engine to. I'll ask them what they'll quote me for the straightening and shortening.
I'll still have to rebuild the axle, but I'm up for that task.
Funny thing is, $150 is cheap for all that work in my opinion, and yet that's DOUBLE what I paid for the axle itself, haha.
Old Mar 3, 2011 | 10:49 AM
  #239
hightower2011
Update on the engine progress here:
https://mustangforums.com/forum/clas...ml#post7443884
I've decided to update my engine progress in that thread so I can keep my plans and progress in one spot, that way I can better keep track of things. Whenever I make progress on it though, I'll probably occasionally update it here with a link to that thread.
Old Mar 12, 2011 | 06:48 PM
  #240
hightower2011
Update time
Primed the roof and rear package tray:
Welded in the new driver side apron panel:
Now dealing with the passenger side battery apron:
The old:
The new:
Lining things up:
Should be welding it in soon
