351 cleveland numbers
I am restoring a 1973 mustang convertible and am getting ready to start on
the engine.... It is a 351-C That I was told is the original motor that cam in the car, but I would like to know for sure. Can someone let me know what these #'s mean that I got off the block?
#92k3
DOAE-J
#92k3
DOAE-J
The Ford part number system does indeed show that part number as 1970, however, there are MANY part numbers that begin being used in a particular year and that part number remains the same until it is changed.
The date code does not seem correct, but IT seems to indicate that the block was cast in 1973. What is the date code of the car itself?
as above the block is 1970 type, not necessarily cast in 1970.
date codes are 3 letter or 4letter
(http://www.carburetion.com/fordnumber.htm),
can you check on that again ?
your number does not make much sense. the other way around makes more sense:
3k29 would be "1973, 29th Oct"
kalli,
you were correct...I did have the number wrong... it is 9K23....
So i guess the date code means 1969 Oct 23rd? should the date code
be the same year as the car or did they put engines in that were made
in previous years? would it be safe to say this is not original for my 73
yes it's 69 or 79, but if it's 79 there would be a better chance the block starting with D3, D5 or even higher. so should be 1969 Oct 23rd.
i would say it's highly unlikely that an engine build in 69 made it into a 73 model car (even if it were produced in 72 already). i would expect 2 months difference max, not yerars
09-23-2015 01:28 PM
