New Brakes Help!!
Old May 12, 2010 | 11:46 AM
Justin Stoppleworth's Avatar
Justin Stoppleworth
Default New Brakes Help!!
Hey Guys, I have aquired new front and rear disk brakes, but i am getting mixed messages on what i need to do about my master cylinder. I have a new dual bowl stock style non-power cylinder and i would like to stick with that, but i have many people telling me i will have to change it?...come on experts..let me know what i need to know...what do i have to do or change in order to use the same cylinder i had for my drum brakes with my disk brakes???
Old May 12, 2010 | 12:41 PM
2+2GT's Avatar
2+2GT
You cannot use a drum/drum master on a car with disc/disc brakes. The disc brakes are valved differently (in the master) than drums. You should be able to use an 84-86 SVO master cylinder.
Old May 12, 2010 | 12:46 PM
kalli's Avatar
kalli
yes, no way you can use the old master. fully agreed
Old May 12, 2010 | 07:43 PM
Gorilla Performance's Avatar
Gorilla Performance
Former Sponsor
Default Help with Brakes
You did not state what calipers you are using. If you are using single piston calipers, it would be marginal because of small reservoirs on the OEM masters and the volume requirements of the big OEM single.
If you are using 1.75 piston in front and 1.38 piston in the back with a .50" pad or less the stock 67 drum brake master will work just as long as you watch the pad wear. You most likely will only get 60-75% out of the pads because the reservoirs are small.
Just make sure the distribution block is taken out, or your wheels will lock up.
You should have about 8 to 12 oz to service both the front and rear system correctly. Anything less than that you will not get 100% wear out of the pads.
Old May 12, 2010 | 08:36 PM
JMD's Avatar
JMD
I was thinking it would work so long as the RPV's are out of the system, we are using a stock 67 M/C and it works well with my son's disks.
Works for us...
Old May 12, 2010 | 08:44 PM
rtintwo's Avatar
rtintwo
Did you use a kit or did you do a swap from another car? If you used a kit then you should follow what the maker recommends.
Old May 12, 2010 | 10:53 PM
Gorilla Performance
Former Sponsor
Default Your Sons Car
Works for us...
Yes, you are correct.
BTY, nice 506hp, wish my dad would have gave me a 500 hp car.
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
