Power Valve Dissasembly
Old Jun 18, 2010 | 12:02 AM
Houndstooth's Avatar
Houndstooth
Default Power Valve Dissasembly
I think I probably damaged my power valve when I removed it. I didn't see Stangersite's strong reccomendation against using a pickle fork until it was too late. I don't know that it would have made a difference, it took my neighbors 20 ton press to get the ball stud out of the pitman.
Anyway, I noticed Chockostang's got the sleeve and housing for sale and I can get a rebuilt kit. The valve was working fine before I pulled it (the slave cylinder mount broke and, well, it's a long story). The problem is I don't know how to get the valve apart. I took the bolts out of the sleeve end but it won't pull apart, do I need to take the screws out of the other end?
Old Jun 18, 2010 | 07:27 AM
chockostang's Avatar
chockostang
To disassemble, the FIRST step is remove the end cap, remove the nut that is very apparent, remove spring, retainers, etc, keep track of the disassdembly. A good idea for the beginner, lay each part out on a table as it comes apart!
Then remove the two bolts that connect the control body to the sleeve. Pull apart, then simply disassemble all the rest.
Dan @ Chockostang
jwog666
Dec 27, 2021 08:09 PM
svfetter
Oct 5, 2015 11:39 AM
Sep 25, 2015 06:58 PM
lmurf60
Sep 24, 2015 10:07 PM
