brake/fuel line
Old Jun 23, 2010 | 10:13 PM
tx65stang's Avatar
tx65stang
Default brake/fuel line
I'm in the process of running the fuel, and have questions regarding the clip locations.
1. the "shared" clips located on the tunnel, are they supposed to hold both the brake/fuel line or alternate between the two.
2. is there supposed to be a clip on the outside of the frame holding the fuel line just before it enters the engine bay to the pump (289)
3. is there supposed to be 1 or 2 clips holding the fuel near the shock
The diagram I have is not very clear, so if this was covered could someone post the link or a diagram of where everything is located.
Old Jun 24, 2010 | 01:42 AM
tx65coupe's Avatar
tx65coupe
The clips hold both lines.
Yes there is supposed to be a clip on the outside of the frame for the fuel line before in enters the engine bay.
I would have to climb under mine to answer your other questions. If no one else responds, I'll try to do that for you.
What part of Texas are you in? I'm in central.
Old Jun 24, 2010 | 06:44 PM
tx65stang's Avatar
tx65stang
The one on the outside of the rail, is it the open ended clip like this?..... ^-
I'm in the DFW area.
Old Jun 25, 2010 | 03:35 AM
tx65coupe's Avatar
tx65coupe
Yeah its more of a flat bracket with a hooked tab on it. It angles down towards the front of the car.
jwog666
Dec 27, 2021 08:09 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
67LimeCoupe
Sep 21, 2015 06:34 PM
